View Poll Results: is it good idea??
Good 0 0%
Needs improvement 2 40.00%
Bad 3 60.00%
Voters: 5. You may not vote on this poll
Old 03-03-09, 02:33 PM   #1
golop
Default Good idea?Switch off-attached to main fuse.
Hi, guys I read all posts about alarms...and my conclusion is that its not worth to buy one ....
Im thinking now to make myself switch on/off, which will be connected to main fuse and hided under fairing or under seat (I dono exactly where to fit it, yet)
(if someone will say: what if thief will find this switch and turn it on, then it doesn't make any sense to fit it)
- I was thinking to fit this switch somewhere In fairing and to use special switch for a key...(to turn it on or off You will have to have special key)
What do you think about this unusual idea??
Old 03-03-09, 03:05 PM   #2
speedplay
Default Re: Good idea?Switch off-attache to main fuse
Ive got a hidden kill switch on my KTM as its got no ignition switch.
I use an electrical cylinder lock as once the key is in place it wont turn off again until the key is removed.
This stops it from cutting out on you.
Old 03-03-09, 03:31 PM   #3
SoulKiss
SoulKiss's Avatar
I dont have to be Tom Jones to say "Its not unusual"
But as most bikes are not ridden off an are usually broken up rather than resold as a whole, I would argue if it was worth it.
Old 03-03-09, 05:36 PM   #4
madness
Before car imobilisers were fitted as standard to cars I always used to rig a switch in the LT circuit and hide it under the dashboard. The thing about security is that anything is better than nothing and the more independent security measures the better. But whatever you do, make sure it won't leave you stranded.
Old 04-03-09, 10:51 AM   #5
golop
Default Re: Good idea?Switch off-attached to main fuse.
thanks for that
Old 04-03-09, 02:53 PM   #6
injury_ian
+1 most bikes are carried into a van etc,
... if you could invent something that increases the weight of your bike 100x whilst parked or even tyres that glue/ bolt to the road, that'd be much more worth it!
Old 04-03-09, 04:17 PM   #7
jambo
jambo's Avatar
On a car, I'm with you.
On a bike it won't stop it being picked up and put in a van, or wheeled off by kids, so it doesn't help, plus I bet you a shiny English pound it'll cause you an electrical fault and leave you unable to start the bike at least once.
Jambo
Old 04-03-09, 04:35 PM   #8
Frank
Jambo
but an alarm will warn you if said van knocks it over ,or kids try to wheel it away
Old 04-03-09, 04:51 PM   #9
SoulKiss
SoulKiss's Avatar
But we were talking about a user-fitted ignition cut-off
Old 04-03-09, 05:08 PM   #10
madness
How about rig a hidden switch to a movement sensor/tilt switch linked to the horn. Someone moves the bike the horn sounds continuously.
Curvey main fuse madness SV Talk, Tuning & Tweaking 2 01-03-09 12:14 PM
Damn Main Fuse GeeMac SV Talk, Tuning & Tweaking 18 09-10-07 12:26 PM
Main Fuse a Blowin' squirrel_hunter SV Talk, Tuning & Tweaking 3 08-12-06 11:17 PM
Help!!! My main Fuse Blows everytime I switch on the Lights moaddog Bikes - Talk & Issues 9 13-06-06 01:40 PM
Main fuse keeps blowing JMCHITTOCK SV Talk, Tuning & Tweaking 7 09-09-05 11:17 AM
