Old 08-03-09, 01:17 PM   #1
TOLAROS
Default Rear wheel speedo sensor
I have two options in mind for my speedo before doing the upside down conversion to my 1st generation SV :
a)Install sensor on the front sprocket axle(just like GSXR) and correct with speedohealer
b)Magnets in the front rotor and sensor
c)Rear wheel sensor.
I Know that some bikes (eg Ducati 999) have the speedo sensor on the rear wheel.
Any info/ideas about rear wheel speed sensor are welcome,because the front sprocket axle idea requires opening hole on the left cover.If I can avoid it it would be good.
Thanks!
Old 08-03-09, 01:58 PM   #2
thefallenangel
Default Re: Rear wheel speedo sensor
http://www.gregoryli.com/search/label/DIY
Old 08-03-09, 02:11 PM   #3
Pointy/curvy?
Old 08-03-09, 02:14 PM   #4
Originally Posted by TOLAROS View Post
1st generation SV
Pointy/curvy?
Old 08-03-09, 02:15 PM   #5
Someone was up early
Put it on back wheel, northwind has done it this way and it seems to work fine. Spindle is same size so it works ok.
Rear wheel speedo drive fix walkthrough northwind SV Talk, Tuning & Tweaking 40 14-11-10 06:47 PM
Speedo sensor. phil24_7 SV Talk, Tuning & Tweaking 5 19-12-07 08:41 PM
Speedo sensor phil24_7 SV Talk, Tuning & Tweaking 9 09-12-07 09:18 PM
Speedo Sensor djt_spurs Stuff Wanted 2 14-11-07 10:09 AM
speedo drive mounting on rear wheel Junior SV Talk, Tuning & Tweaking 1 20-01-05 06:05 PM
