Hi
just joined the group and was hoping someone can help, i was coming off the motorway today the speedo just stopped working, i know its not cable question is do i have to buy a new speedo drive complete or is there anything inside it that breaks and can be replaced |
what year bike-take front wheel off and check the rotors ok-if not you can buy replacement from robinsons
thanks for the reply its a 2003 naked, took the front wheel off and everything seems ok, look like i will have to get a new one
pointy or curvy
Has the lead simply come disconnected from the wiring, it's a plug that plugs into a connector !! Has the wiring split anywhere ? Or...
Take the front wheel off and have a look at the speedo sensor which comes in two bits. Inside the sensor unit is a little plastic rotar with 3 sprockets, the sprockets are prone to snap and costs about 20 quid I'm told to replace. Or........ which is what happened to me, the more expensive thing to go is the actual sensor. If the sensor is plugged in properly and the cable isn't split anywhere and the rotar is ok then the actual sensor has died and there is no way in to fix it...... £106 +VAT to replace !!! |
A big thanks to everyone who replied unfortunately it was the drive its self that died so had to buy a complete new one, and glad to say back up and running once again thanks
speedo drive | Monkey_SDMF | SV Talk, Tuning & Tweaking | 19 | 18-11-08 03:19 PM |
Help! Need a speedo drive | richwill68 | Stuff Wanted | 6 | 27-03-08 03:09 PM |
Speedo drive | goody | SV Talk, Tuning & Tweaking | 0 | 13-08-07 07:30 PM |
speedo drive help | johndo | SV Talk, Tuning & Tweaking | 8 | 30-04-07 08:46 AM |
Speedo drive | Normski | Stuff Wanted | 0 | 02-12-05 04:52 PM |
