Old 12-03-09, 06:15 PM   #1
decca1o
Default Constant Draining Battery
Hey all, I end up changing the battery on my bike once a week. It is fine in the summer, but anytime it gets below 50 degrees, I usually have to change it. I have read many posts about the cold killing batteries, but it seems to be happening way to often and when it is not that cold out. Any ideas?
Old 12-03-09, 06:16 PM   #2
Default Re: Constant Draining Battery
Check the charging system.
Old 12-03-09, 07:13 PM   #3
decca1o
I also forgot to mention that the battery has gone dead within 24 hours before (I have two different batteries also). I would guess that it is not the charger.
Old 13-03-09, 10:22 AM   #4
Tiger 55
Not the charger, the charging system. This sort of thing...
Check the voltage to the battery, it should be 13.5 to 15.5 at 5000rpm with the lights on.
If not, check the red wire that goes to the RR has continuity to battery live and the black has continuity to earth.
Then check the alternator output, should be 70v (AC, not that I'd ever forget that...) between each of the yellow phase wires and any other.
Measure the voltage across the battery 30 mins after a charge
measure it again with the engine running at about 5000 rpm and lights on
the above is sufficient to tell us if the charging system is working or not.
I would expect to see something about 13 - 14V.
If not. disconnect the 3 yellow wires going into your RR
think of them as a,b,c. Turn your multimeter onto the ac voltage scale and measure the voltage between ab, ac, and bc. you should be seeing something about 70-90v. from the alternator
if the alternator reads ok and you are not getting the charge to the battery it is a goosed RR. Go out and buy a nice one from a Honda. muller the connections to fit. or source a reputable pattern part.
If the initial check was ok and you were getting the 13-14v. Leave the bike overnight and measure the voltages again in the morning.
alarm draining out battery abdul.aziz SV Talk, Tuning & Tweaking 2 10-05-09 12:56 PM
Constant beeping during DVD playback DarrenSV650S Idle Banter 1 02-02-09 11:35 PM
Battery draining - Help PaulyMac SV Talk, Tuning & Tweaking 19 01-06-07 09:30 AM
Are my carb heaters draining my battery? svrash SV Talk, Tuning & Tweaking 12 27-12-06 11:13 PM
