Old 15-03-09, 03:15 PM   #1
AndyL
Default Problem with Hugger
My rear hugger was fitted to my bike (pointy) when it had its first service (it is a pyramid plastics hugger), I have since travelled 400 miles on my bike and noticed that when ever I seem to go over any loose stones or gravel on the road that the tyre picks them up and scrapes them on the inside of the hugger making the worst of noises. Does anyone else have this problem and what did they do too fix the problem? The only thing I can think of doing is re-drilling the fixing holes in the hugger so that it can be mounted a little bit further away from the rear tyre. Any other suggestions (helpfull ones ) are welcome.
Cheers,
Andy
Old 15-03-09, 03:34 PM   #2
Default Re: Problem with Hugger
couple of washers under the bolts?? to lift it higher. Did it to mine when there wasn't enough clearance for the tyre. Worked a treat!
Old 15-03-09, 11:15 PM   #3
skeetly
skeetly's Avatar
+1
I altered mine today and it does the trick
skeetly is offline   Reply With Quote
Old 15-03-09, 11:59 PM   #4
i used to undo all the fixing points loosely then lift the hugger then re tighten.
Old 16-03-09, 12:04 AM   #5
skeetly
skeetly's Avatar
tried that and the bloody thing still woudlnt lie right
Old 16-03-09, 08:06 AM   #6
AndyL
What did you do to adjust it then? Did you re-drill the holes in the hugger?
black rear hugger or carbon rear hugger? chipnix SV Talk, Tuning & Tweaking 9 05-07-07 04:05 PM
hugger problem.................. maff Bodywork 0 10-05-07 02:56 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
To hugger or not to hugger? That is the question!! CatfordSV SV Talk, Tuning & Tweaking 5 27-03-05 10:44 AM
