Old 17-03-09, 05:14 PM   #1
Baph
Default Pointy (k6 compat.) clocks
As per the title, does anyone have these kicking around anywhere?
I'm not sure if the pointy clocks remember mileage/trip counters, or if the ECM does this. But I'm really not bothered about mileage if they do.
Reason for wanting one? My LCD has given up the ghost it would seem, meaning I have no speedo amongst other things.
Old 17-03-09, 05:30 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Pointy (k6 compat.) clocks
You planning on having a play with the dead clocks, if not, I wouldn't mind having a tinker
Old 17-03-09, 05:35 PM   #3
Baph
They're happily yours mate once I've got a replacement. I've already had a fettle with the connector on the back (resistance/continuity/voltage on all pins with ignition in both states) - just I haven't opened it up yet.
I'll post my findings later to confirm my thoughts on screwed clocks.
Old 30-03-09, 03:27 AM   #4
Baph
Nobody got one kicking around? Pah.
Suppose I'll have to be buying a new set then...
(sneaky bump BTW, did you notice? )
Old 30-03-09, 09:16 AM   #5
21QUEST
21QUEST's Avatar
Baph, got one off a K5...well it's either a K5 or K6 as I know it came off a black framed bike. I was going to put it on a Curvy but no chance of that now.
It has a little a little crack(next to mounting bolt) on the plastic backing. You can easily swap yours with it , though not really needed.
Mileage is very low . I did check the mileage with a friends bike but can't remember now, how many miles it had but would be between 3K and 6K I believe. Certainly not much higher or lower than that....and for sure lower than the recorded miles on yours
Anyhoos cost me £125 plus postage but yours for £110 posted. If it suits your requirement, let us know addy and I'll stick it in post tomorrow. We can sort the monies out once you've got it.
Ben
Nemo me impune lacessit.
Old 30-03-09, 11:06 PM   #6
Baph
Ben, sorry, you're having a giraffe right?
There's some on evilBay for £90. I'm half tempted to just stick a Vapor set on it though TBH, as they're even cheaper than OEM.
Thanks for the thought though dude. (unless you want to price match ).
Old 31-03-09, 07:53 AM   #7
21QUEST
21QUEST's Avatar
baph, you cheeky git
You have a PM
Ben
Old 31-03-09, 11:24 AM   #8
Baph
Muchos gracios amigo.
You have one back.
Old 31-03-09, 05:13 PM   #9
zadar
You have a PM
Ben
btw. clean your pm box
Old 02-04-09, 08:34 PM   #10
Baph
21Quest or me?
Mine are now cleared.
Though it's only fair I state that I've now received new clocks, and have yet another problem.
pointy bits ecu clocks samas2501 For Sale - SV's and SV related items 3 01-06-09 04:24 PM
Pointy clocks diagnosis - am I right? Baph SV Talk, Tuning & Tweaking 10 02-04-09 07:49 PM
Pointy Clocks - Urgent RGV250ads Stuff Wanted 0 21-02-09 04:13 PM
Removing Clocks, Adding LEDs? (Pointy) Jdawg SV Talk, Tuning & Tweaking 6 08-07-08 09:11 PM
Clocks or no Clocks Demonz SV Talk, Tuning & Tweaking 15 04-07-08 03:55 PM
