Old 24-03-09, 06:16 PM   #1
LooneySV650S
Default Up-grading the handling of a SV650S
I want to up-grade my sv's handeling. Can I change the springs in the forks or should I go for a entirely new front end (eg a gsxr's front end) I have a limited budget. I just use it for road use, no racing.
Old 24-03-09, 06:18 PM   #2
madness
Default Re: Up-grading the handling of a SV650S
welcome to the Org.
Do a search of threads as this topic has been done to death already
Old 24-03-09, 06:41 PM   #3
Dave20046
Dave20046's Avatar
hagon progressives and renewed oil. cost you about £70
gixxer shizzle starts to get £££, do a search
Old 24-03-09, 06:55 PM   #4
gazza
Fit a quality aftermarket shock,(Hagon are good for the price), and fit linear springs and 10w oil. There isnt enough fork travel for progressive springs to work properly, the travel only uses up the soft part of the spring so it doesnt feel to much firmer than standard,
Old 24-03-09, 06:57 PM   #5
Dave20046
Dave20046's Avatar
never knew that, my progressives don't feel bad though.
Doesn't the weight of the oil depend on the rider though?
Old 24-03-09, 06:59 PM   #6
dunno why you'd think that. I've got Hagon throughout on one of mine(progressive front 15W oil), and the handling is an absolute dream, they compliment each other considerably, in comparison to stock bouncy castle. Plus the SV knock, is muted to practically nil.
I've got linear in the other, and I'm not only keen on them at the moment.
Old 24-03-09, 07:14 PM   #7
If you can turn a spanner then go for GSXR bits. If not, go for a set of springs.
I wouldn't bother with an emulsion type shock, I think £250 is well over the odds for what is a pattern part.
As for progressive springs and travel, your preload is not set right ... but yeah I would go for linear.
Old 24-03-09, 07:20 PM   #8
Dave20046
Dave20046's Avatar
Is shimming them up the only way to set preload chris?
Old 24-03-09, 07:22 PM   #9
Get K2 fork tops with the preload adjusters.
Old 24-03-09, 07:24 PM   #10
Dave20046
Dave20046's Avatar
Just the toppys? Sounds almost too simple lol.
What's the going rate any ideas?
What does Handling mean? Stu Bikes - Talk & Issues 22 17-01-09 10:49 PM
Handling. Lozzo SV Talk, Tuning & Tweaking 62 02-09-07 05:41 PM
sv handling mic-hull SV Talk, Tuning & Tweaking 8 29-06-07 09:26 AM
GSXR 600 K1 Handling - Anyone help ? mattyL Bikes - Talk & Issues 9 22-05-07 08:38 PM
sv650s better handling on k5 Welsh Wonder SV Talk, Tuning & Tweaking 1 03-09-05 06:42 AM
