Old 26-03-09, 01:36 PM   #1
hovis
Default how do you clean a K&N air filter?
do you need the K&N cleaning kit
Old 26-03-09, 01:53 PM   #2
Viney
Default Re: how do you clean a K&N air filter?
Hmmm, i think its no more than carb cleaner or similar. You can use and airline and blow form the inside out. To b honest, they have a usable life uto about 30000 miles before they need cleaning.
The Cleaning kit does come with cleaner AND the oil you need to re oil it.
Old 26-03-09, 01:59 PM   #3
It's not a solvent cleaner... more like a soap, it's wierd stuff, it makes the oil soluble in water. Worth getting the kit, or a bit of google-fu to find out a backyard replacement.
(the filter oil you can get all over the place, my local place for the off road bikes does it pretty cheap)
Old 26-03-09, 09:52 PM   #4
Echo what Chris says - don't use a solvent on the filter, they get damaged quite easily in the wrong stuff.
Old 26-03-09, 10:00 PM   #5
Razor
I washed mine with dry cleaning fluid, seems ok.
Old 26-03-09, 10:36 PM   #6
Not that I'd thought of that before, but I'm sure you're right. The K&N is made of a fibrous material that may well be organic - dry cleaning fluid sounds like a good idea.
Clean!! its soo clean!! + chain question John 675 Photos 13 07-03-09 07:14 PM
Just had a clean Franco1 Photos 11 03-05-06 10:59 AM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
clean SV K5 jonhunt Photos 11 27-12-05 04:39 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
