Old 30-03-09, 07:53 PM   #1
chompy
Default diagrams!
could anyone point me in the dirction of some diagrams for the fairings on an 01 sv650s because i took the crash damaged ones off, and forgot where all the bolts go
any help
Old 30-03-09, 08:04 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: diagrams!
see where all the holes are, thats where the bolts go
1) you need to fit the center panel first, two bolts under the fairing and two on the upper edges
2) fit each side panel, it should clip into the rad, one bolt on the side of the frame one bolt, two bolts for the mirrors, one hole next to the clocks on each side
3) small screw in each of the airvents
4) put screen on and bolt it in place, not over tight as they are rubber gromets
lowers, horible things... cant remember how to fit them as once i damamged mine i never fitted them again.
Old 30-03-09, 08:09 PM   #3
chompy
yeah i know where the holes are but there is a small hole on the inside by the forks attaching the centre to the bikini i dont know what goes there as i dont have a bolt for it and there si nothing for it to screw into.
i got sent a link for all parts and diagrams it would be good if i could get that
