Old 02-04-09, 08:46 PM   #1
James SV
Default Rad Fans- what temp
Hi there, Just wondering at what temperature should the radiator fan come on, on a k4 pointy sv650? Just wondering as im new to the world of SV's.
Thanks alot,
James
Old 02-04-09, 08:51 PM   #2
bigspud
Default Re: Rad Fans- what temp
hi mate ,welcome aboard,mine is a k6 and fan comes on @103 and goes off again@98,normal running is around 84/88
Old 02-04-09, 08:53 PM   #3
James SV
Ah ok, I had the bike to 100 degrees and was getting worried as the fans were not comming on. 3 degrees more and they should come on then
Thanks alot
James
Old 02-04-09, 08:55 PM   #4
CarlosSV650S
Mine went to 107 the other week an it hadnt come on.
My normal running temp is bout 78
Old 02-04-09, 08:58 PM   #5
simesb
Never had mine on.
Temp rises to low 90s, drops to high 70s when the thermostat opens, and is usually in the mind 80s.
Just doesn't get hot enough for the fan.....
Old 02-04-09, 09:02 PM   #6
keith_d
keith_d's Avatar
I've just replaced my fan switch after mine reached 107 and cut out in traffic on the way to Soho. I bypassed the switch and the fan worked fine, so the switch was the main suspect.
Unfortunately, I don't stop much on my way to work so there's always plenty of airflow. Hence, I won't find out if I've resolved the problem until tomorrow. Maybe I'll pack a paper clip so I can short the switch if I overheat tomorrow.
Keith.
Old 02-04-09, 09:03 PM   #7
AmigaNut
As above on a K7.
Old 02-04-09, 09:36 PM   #8
mackrilld
Ive only had it on twice once when i first got the bike but had no licence so was running in my drive and me reving it up lol and the second on a really hot day in solid traffic other wise ive riden it pritty hard sometimes all day and temp has not gone above high 80's low 90's
Old 02-04-09, 10:05 PM   #9
Kilted Ginger
Just after i got the bike I was caught in a traffic jam and i heard the fan come on, looked down and the temp was 96, couple of miutes later, fan still on, temp 99, another couple of minutes, fan went off temp 101. mmm slightly confuded. another couple of minutes temp at 102, still no fan, started switching the bike off when the fan was stationary but the temp was still climbing very slowly but climbing and still no fan, It hit 107 and was about to pull over to the side of the road when I realised i was taking the temperature reading from the odometer, surprisingly my temp is now above 10000 degrees
Old 02-04-09, 10:49 PM   #10
ogden
ogden's Avatar
Like most bikes it'll come in around 100 and go off when the temperature goes back below.
I don't think I ever really had it on my SV but my GSXR750 was a swine for getting hot in town - it'd spend most of the journey from Wandsworth to Tower Hill between 100 and 110. The thou, oddly, kicks out far less heat.
Either way, don't worry about it. Only worry if the temp hits 110 and the fan hasn't kicked in yet. Then you're stuffed.
ogden
S1000XR | 990SMT | YZF-R6 #7
ogden is offline   Reply With Quote
At what temp should the fan cut in? Unlucky4some SV Talk, Tuning & Tweaking 21 19-10-08 03:32 AM
engine temp avvacuppa SV Talk, Tuning & Tweaking 7 13-09-08 07:37 PM
For the car fans on here and my photography fans ScottishRawker Idle Banter 11 02-09-08 12:11 PM
Fan on temp bobw SV Talk, Tuning & Tweaking 12 01-07-08 08:40 AM
Normal Temp Red Herring SV Talk, Tuning & Tweaking 5 17-03-08 09:59 PM
