Bikes done over 11k with original chain.
I checked the 'stretch' as per the manual by measuring between pins while tightening it today. It's got another 3mm of stretch to reach the stated service limit. I quite fancy another chain and sprocket for bling value but be nice to know if I've got ages left or not. |
If you have looked after it and continue to do so it will do double that mileage easily.
scottoiled since I had the bik (4k) so it should be OK I guess....
My K1 got to 43,000 on the same chain and sprockets, just. It did have a scotoiler fitter from new and also never wheelied etc. So yep that chain should carry on. I'd also check the sprockets for wear to confirm all is well and that the chain has no tight spots.
The Sick Man
All depends on how you ride, my SV is not ridden smoothley, i love the instant go and wheelies etc, ive had my chain on my SV for about 20k now, but ive gone through two front sprockets, its got scottoiler on it but its now comming to the end of its life, i can pull it enough off the rear sprocket that you see the teeth
hardly know anyone that measures between the pins
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Ta fer feedback. The sprockets are fine. I'll stop worrying then
Make sure your Scottoiler is working right and oiling well. If it doesn't for a short while its easy for older chains to dry out quick as the seals might be well worn. As said before bikes can do 25K on original equipment reasonably easy.
Chain Always Loose, New Chain? | RGSPro | SV Talk, Tuning & Tweaking | 8 | 02-07-10 10:05 AM |
Cam Chain | jambo | Stuff Wanted | 6 | 05-08-08 10:28 AM |
Chain on the way out? | krhall | SV Talk, Tuning & Tweaking | 5 | 20-04-08 07:14 PM |
Morax Gold Chain Wax / Wurth Chain Wax | glade | Ancillaries | 3 | 14-02-08 06:41 PM |
Will stiff chain link cause chain noise | dclifford | SV Talk, Tuning & Tweaking | 8 | 16-08-05 11:56 AM |
