Old 15-04-09, 08:09 AM   #1
Ter
Default Suzuki GSXR K5 600 Radial Master Cylinder + Lever
Having a clearout,
This is surplus - MC is in good working order with no marks. Comes complete with reservoir, reservoir mounting bracket and good brake lever. Also comes with a bent lever that you are welcome to throw away or keep in the toolbox as a 'get outta trouble' spare.
Looking for [PRICE=£65] posted 1st class recorded.
Will work with a multitude of other bikes also! Perhaps the whole GSXR family. Came from a 7K mile GSXR 600 K5 but would work with the SV650 no problems, have one on mine!
Got it with me today so can post today so you could have it tomorrow/Thursday.
Old 15-04-09, 11:11 PM   #2
Stu
Trinity
Stu's Avatar
Default Re: Suzuki GSXR K5 600 Radial Master Cylinder + Lever
Nice Gixerbot friendly ad
So how much of an upgrade would this be? do you think it would fit a G1 ZX6R?
I'm guessing Clip ons are std 22mm size? & this is everything up to the brake lines? And there's a brake light switch connector?
Old 15-04-09, 11:14 PM   #3
TSM
The Sick Man
TSM's Avatar
I tried on my 636, it did fit on the bar but i could not get the stock lines to fit as they were designed to fit on the end of a normal MC, mabey the G model lines are longer as the bars are on top of the yokes unlike the J & 636.
Old 15-04-09, 11:28 PM   #4
Stu
Trinity
Stu's Avatar
I don't have stock lines, i have braided, but I would guess they are stock length.
where do the lines attach? i can see the bleed nipple on top but nowhere that thelines attach? is it underneath?
And what about how much of an upgrade this would be? is it a matter of matching a radial lever to radial calipers? or each of those would be better than non radial?
Old 15-04-09, 11:30 PM   #5
TSM
The Sick Man
TSM's Avatar
Its underneath, so theywould have to do a 90 deg bend.
I dont know how they work on 6pots, ive got them on GSXR 4pots on the SV and its way more than enough, sharp, i like it.
Old 15-04-09, 11:31 PM   #6
Radial M/C works fine with axial calipers.
Radial M/C is more rigid.
Old 15-04-09, 11:32 PM   #7
TSM
The Sick Man
TSM's Avatar
the problem is not if its radial or standard calipers, its 6pot vs 4pot calipers, whats the diffrence
Old 15-04-09, 11:34 PM   #8
Stu
Trinity
Stu's Avatar
Thanks
Old 15-04-09, 11:35 PM   #9
Piston area is only difference that matters. More pistons but same size MC = more advantage. But go too far and you won't move enough fluid to get the pistons to contact the disc.
Try it, I think it will work if the brake lines are ok.
Old 15-04-09, 11:37 PM   #10
Stu
Trinity
Stu's Avatar
So it's moving more fluid for the same movement? i.e. moving the brake pads more.
Why would it not work just the same on 6 pots?
GSXR Radial front brake master cylinder DanF For Sale - SV's and SV related items 8 16-03-08 11:24 PM
Radial Front Master Cylinder. petevtwin650 SV Talk, Tuning & Tweaking 5 17-11-07 12:16 AM
Brake parts- EBC pads, GSXR radial master cylinder northwind For Sale - SV's and SV related items 10 03-09-07 07:33 PM
Radial Master Cylinder? squirrel_hunter Bikes - Talk & Issues 4 28-07-07 10:17 PM
Swap GSXR forks/radial brakes/radial master cylinder/wheel Teknic SV Talk, Tuning & Tweaking 2 16-03-05 07:19 AM
