Old 20-04-09, 02:00 PM   #1
ooger
Default MOT before time?
Assuming I have a valid car MOT, and suspect that the car won't pass the next MOT, and get the MOT done BEFORE (11 months after) the current one expires, and the car fails.....
Does that mean I have a valid MOT still, because of the original one which has not yet expired?
Or does the new failure override the present one?
(odd question, I know, but I'm thinking of selling the car "with" an MOT)
Old 20-04-09, 02:10 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: MOT before time?
You just need a valid MOT so the new fail does not overide the old ticket.There may be a separate issue about whether your car is roadworthy or not,but thats nothing to do with the MOT.
Old 20-04-09, 02:14 PM   #3
rictus01
rictus01's Avatar
the new system will record the failure, you may get away with the producer part if called upon to do it, but the vehicle will have been proved below standard by the test, and this information will be available to police threw their system.
So you'll have a proved unroadworthy vehicle which of course you can get done for at anytime.
Cheers Mark.
Old 20-04-09, 02:14 PM   #4
Mr Speirs
Mr Speirs's Avatar
What biker biggles said.
Also If you have a valid MOT certificate and want to do it early as long as you provide the current MOT cert they will post date the new MOT certificate up to 1 month which in effect would give you a 13 month MOT.
Old 20-04-09, 02:32 PM   #5
ooger
Thanks,
Basically I'm toying with the idea of getting a leased car through work, but I reckon the emissions on the current one will warrant a replacement exhaust and/or cat at the MOT in May, so I'll get it done ASAP just to "test the water"
If its up the chuff to the value of several hundreds I'd rather know sooner than later! A new exhaust might double the value of the damned thing!
long time browser, first time poster in need of help stevo_sv Stuff Wanted 8 01-11-08 01:43 PM
Long Time Reader, first time poster Oli Idle Banter 71 07-06-07 11:32 AM
About time too!!! PaulyMac Photos 10 06-06-07 04:53 PM
It’s that time of year again … Renewal time … Blue_SV650S Bikes - Talk & Issues 19 31-12-06 06:51 PM
Good cause time, need your time, not money! Spiderman Soho Massive 4 21-03-05 06:24 PM
