Old 21-04-09, 10:22 PM   #1
simonthepost
Default over 4000rpm
bin inactive for a while but here goes, was riding my sv uptill the snow in feb, garaged it and left it. rode it again after and was very juddery seemed to not like an open throttle, then would take off, took the tank off drained it and the carbs, still the same.now wont start. any ideas?
Old 21-04-09, 10:53 PM   #2
Jamiebridges123
Default Re: over 4000rpm
Try running some hi octane stuff with that stuff you can get to stop carb icing. Run that through for a tank and see if that helps..
Old 22-04-09, 07:53 AM   #3
Alpinestarhero
Have you been getting this problem in the recent warm weather? Some higher-octane stuff could help, but only if its carb icing; you may need to balance the carbs. I used to get a bit of a hesitation at approx. 4000 rpm, until I fitted my fuel exhaust
Old 22-04-09, 09:49 AM   #4
chompy
does it do it all the time or when you first set off, my does it if it isnt warm enough when i first set off and then is fine after that
Old 22-04-09, 03:40 PM   #5
Biker Biggles
Biker Biggles's Avatar
Choke plungers and cables.
Old 22-04-09, 05:29 PM   #6
simonthepost
update:took everything off again today,tank, airbox etc drained fuel bowls,spark plugs out cleaned and gaped,poured stuff into carbs to start it (ironically called 'start yer basterd!!) and it did it ran fine! so obviously a fuel issue. Drained the tank and cleaned it out noticed after the petrol had settled in the container from the tank that there was a milky liquid in the bottom?? Put everything back cleaning as i went and it runs fine now no flat spotsw or hesitation at all, so whatever the stuff was in the bottom of the tank was obviously to blame.
Thanks to everyone who replied with help it did!
Old 22-04-09, 06:58 PM   #7
Hey, it wouldn't start before because there was nothing in the carbs, turning it over a while lets the float bowls refill. (it's a vacuum fuel tap with no "prime" setting, cheers suzuki...)
Check that the drain pipe through the tank from the filler cap is a) not blocked and b) not venting to the inside of the tank. Normal condensation can also end up in the fuel.
Old 22-04-09, 11:04 PM   #8
simonthepost
turns out that the milky stuff in the tank and float bowls was water blimey someone doesnt like me, was nearly a pint!
Idling High (4000rpm) once warm SV_Ridin_Newb SV Talk, Tuning & Tweaking 3 16-08-07 05:16 PM
ticking/rattle begins at just over 4000rpm SV650S_DUB SV Talk, Tuning & Tweaking 5 04-08-07 03:25 PM
Carb syncing at 4000RPM not Idle!?.. kciN SV Talk, Tuning & Tweaking 19 11-05-06 02:08 AM
