Old 25-04-09, 02:34 PM   #1
dafne
Default What undertray is this?
Hello!
The undertray I have on is a little bit broken (as you can see by the zip ties in the last pic) as one or two of the lugs have broken. Its also been bodged slightly where the battery is.
What undertray is it? As you can see, the fit isn't great under the seat so i'm assuming its off the wrong version, but does anyone have any idea? (I was thinking a slightly modified TCP one?) Also, any suggestions for getting rid of the big number plate light and putting a smaller plate on, whilst making sure it looks tidy?
Old 25-04-09, 05:25 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: What undertray is this?
Looks like the Suzuki OEM tray, which is made by TCP as you suggest.
Old 25-04-09, 09:49 PM   #3
dafne
Presumably then, there aren't supposed to be those gaps either side of it?
Old 26-04-09, 07:06 AM   #4
fizzwheel
fizzwheel's Avatar
I cant remember and I dont have my SV anymore to compare, I've only got one or two pics of the back end with the tray fitted, this is probably the best one I've got.
dont know if that helps or not.
I know that Northwind had an OEM tray and he suffered I think from some broken lugs, Mine also cracked around the batery tray so it might be a common problem.
Old 26-04-09, 11:47 AM   #5
dafne
Yeah, it looks like you had the same gaps either side that I do. It would be a shame to get rid of it, so i'll have a go at re-fibreglassing it. Can you remember how it was fitted (with regards to bolts and whatnot) as mine has different fittings either side
Old 26-04-09, 11:51 AM   #6
fizzwheel
fizzwheel's Avatar
I really cant remember, but... I was tidying up a couple of weeks ago and came across the fitting instructions for it. Reading your post has just reminded me that I still have them and I've fished them out.
If you let me know your address I can post them onto you if you want them, they're no good to me anymore...
Old 26-04-09, 12:28 PM   #7
dafne
Yeah, that'd be great! Thank you
Undertray Gary C Ancillaries 1 28-05-08 09:33 PM
undertray Quiff Wichard Bikes - Talk & Issues 7 05-04-07 08:01 PM
new undertray bobthebuilder Photos 8 12-12-06 08:16 PM
What undertray Grinch SV Talk, Tuning & Tweaking 10 29-04-05 01:01 PM
Undertray K4 jordyal SV Talk, Tuning & Tweaking 11 11-04-05 10:10 PM
