Old 29-04-09, 03:48 PM   #1
svdemon
Default K3 GSXR 600 Forks on a pointy
Has anyone done this before? And if so any pics? I'm looking to do this shortly so trying to figure out which wheel etc to use.
Old 29-04-09, 04:44 PM   #2
Default Re: K3 GSXR 600 Forks on a pointy
are they RWU or USD forks... i'm guessing RWU...
front wheel is GSXR 1000, 750, 600 K1-K4 to be safe..
get same year yokes, mudguard, clipons, calipers, discs for forks..
your friend:
http://fiche.ronayers.com/Index.cfm/.../2/Make/Suzuki
use it to cross reference parts.....
Old 29-04-09, 06:23 PM   #3
K3 is RWU.
Use the lot.
Yokes fit straight in, stem and bearings are the same.
Clipons are too low, use proper bars or maybe some from a VTR1000 firestorm
Fork legs... duh
Calipers SV1000, K1-3 750s, 600 or thou.
spindle, mudguard 600 or 750. not sure about thou.
wheel, everything up to 05 6/750. or up to 04 thou.
discs. 320mm. flat. AFAIK they're the same as SRAD6 /750, TLS, TLR and 'busa.
Old 29-04-09, 06:37 PM   #4
have you thought about how you are going to drive the speedo?
if you are going to use magnets/hall unit, i would stick to the OEM discs.. i had a look at the after market discs but found all of them to have odd numbered disc rivets...
if you get stuck.. gives a shout. i'm only over the water from you and always in edin...
Old 29-04-09, 07:28 PM   #5
svdemon
So far i have forks, clip ons, spindle, brake calipers, mudguard all form a GSXR 600 K3.
I need a wheel and a set of discs and then a speedo workaround.
So i can re-use my SV head bearings? That is good news, i'll sell the clip ons and get VTR ones and rebuild the forks before i fit them.
So, any GSXR wheel from K1 to K4 roughly? I'll try to find one in silver to save me painting it!
Old 29-04-09, 09:04 PM   #6
Have a compare first. I think the GSXR clipons will drag cables on your fairings. And be uncomfortable.
Old 30-04-09, 03:43 PM   #7
svdemon
I'll flog the gsxr clip ons for VTR ones if they are the ideal rise etc. Can anyone confirm?
Old 30-04-09, 03:46 PM   #8
I'm pretty sure the K1 600 is a 43mm fork stanchion same as the VTR. Not sure about rise.
Old 30-04-09, 09:36 PM   #9
Binky
Emily Howard rides an SV
Binky's Avatar
Just one thought, is a working speedo a legal requirment for a road bike???
Wowee Zowee
Old 01-05-09, 12:31 AM   #10
They don't test it on MOT. But you'd be daft not to IMO. Even a bicycle speedo is better than nothing.
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
Definitive K3 GSXR 600 (RWU) Forks - K3 Pointy Thread svdemon SV Talk, Tuning & Tweaking 24 15-07-08 01:21 AM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
gsxr k6/7 forks maff SV Talk, Tuning & Tweaking 7 10-02-08 06:02 PM
gsxr forks on the sv k3? kwak zzr SV Talk, Tuning & Tweaking 12 11-12-06 11:50 AM
