Old 29-04-09, 11:46 PM   #1
Nicky S
Nicky S's Avatar
Default adjusting headlight
on a sv650 n
i know that you have the bolt on the left of the headlight and the one on the bottom. the one on the side is for moving the headlight left and right and the bottom is for up and down ... am i right?
well here is my problem just taken my bike out and the headlight is faceing the sky. the bottom bolt is screwed in nearly all the way so why is it not pointing down HELP or am i doing it all wrong ?
i did do a search but all i found was how to do it on a s
cheers nicky s
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 29-04-09, 11:48 PM   #2
Default Re: adjusting headlight
Try turn the bolt the other way.
If not put it in the middle and move the headlight in the clamps.
Old 29-04-09, 11:52 PM   #3
Nicky S
Nicky S's Avatar
cheers YC
anything else i can do or is that it ?
Old 29-04-09, 11:56 PM   #4
Make us a cuppa tea, maybe some malt loaf? Really, the world's your oyster, go for it. Carpe Deum.
If moving the whole unit on its mounts doesn't get it to the proper height then the proximity of so much pi$$ weak beer down south must be altering the laws of physics.
Old 29-04-09, 11:58 PM   #5
Nicky S
Nicky S's Avatar
ahhh now thats a bit strong for the fact it is nearly one in the morning but cheers for your help YC
Old 30-04-09, 12:06 PM   #6
vardypeeps
LOL some people where up late!
I would just rotate it in the mounts if it's the dominator headlights in the pic
Old 30-04-09, 02:11 PM   #7
Nicky S
Nicky S's Avatar
i think i have done it. did it this morning but im not sure if the screw and spring are in the right order.
i have done screw washer then bracket then spring then headlight then nut is this right ?
adjusting speedo 01 sv650s SV Talk, Tuning & Tweaking 4 27-02-07 11:18 PM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
Headlight Mounting bracket, headlight vincerhodes Stuff Wanted 1 10-05-06 07:12 PM
Adjusting Clutch echomadman SV Talk, Tuning & Tweaking 5 16-05-05 03:41 PM
adjusting the headlight Lolo SV Talk, Tuning & Tweaking 3 31-01-05 09:18 PM
