Old 30-04-09, 03:00 AM   #1
lukemillar
Default Exhaust repacking
Need to repack my exhaust at the weekend as it is annoyingly loud. Got me some packing a and a rivetter, but thought I'd check what size rivets do people use, before buying a big box of rivets.
Tool came with 4 adpaters:
3/32"
5/32"
1/8"
3/16"
Does it vary from exhaust to exhaust?
I'm a rivet virgin
Old 30-04-09, 03:44 AM   #2
rictus01
rictus01's Avatar
Default Re: Exhaust repacking
yes it does vary between exhausts, check the size you've got currently fitted (probably 3/16), and make sure to get steel rivets and not alu ones ( as they will wear very quickly and come loose).
Cheers Mark.
Old 30-04-09, 11:21 AM   #3
johnnyrod
johnnyrod's Avatar
My Akrapovic has 3/16" i.e. 5mm ones. I went to the bother of finding stainless blind-ended ones, which you need to be the Hulk to use by comparison to ally ones. Had to repack the can just over a year later so am wondering if it was worth the bother of SS rivets!
PS. If you're drilling out the existing stainless ones, you could do with a cobalt tipped bit, keep the speed low (cordless drills are good for this) and splosh a bit of water on it - you need to keep the temperature down otherwise the stainless hardens and destroys your drill bit.
Just another issue. Exhaust repacking. BBadger SV Talk, Tuning & Tweaking 10 26-04-09 12:51 PM
Repacking Exhaust Lucas SV Talk, Tuning & Tweaking 2 15-03-09 10:14 PM
Repacking renegade cans - what sealant? kinesin SV Talk, Tuning & Tweaking 9 20-02-06 04:41 AM
Repacking end cans northwind SV Talk, Tuning & Tweaking 9 31-03-05 02:07 AM
Repacking? MitchC SV Talk, Tuning & Tweaking 7 25-02-05 09:14 AM
