Old 30-04-09, 03:51 PM   #1
joyceville787
Default How to fit a tail tidy?
Just bought an rrse end tail tidy for a K4 SV650s, how do I fit it as theres no instructions and I dont want to bodge it up???
Old 30-04-09, 04:16 PM   #2
Mgaffz
Default Re: how to fit a tail tidy
You'll probably find a guide on the net i would imagine. Never seen one so cant give anymore accurate info sorry.
mick
Old 30-04-09, 04:54 PM   #3
ukgooner
Default Re: How to fit a tail tidy?
How about this place, really good info on SV's apparently
http://www.sv650.org/
Old 30-04-09, 04:56 PM   #4
Jamiebridges123
Generally you just undo the indys, take the rear seat and tool tray out, undo the bolts, bolt the new one up and bobs your uncle.
What tail tidy did you buy? If it's an R&G or Evotech one, they have instruction manuals avalible from their website in .pdf Format.
Old 30-04-09, 04:59 PM   #5
RichT
If it's the RR Send generic tail tidy - I think you'll have a job fitting it. They are designed to bolt to an undertray that has a "ledge" or fitting point for the rear plate.
Fleebay it or send it back and get yourself a Hamicad.
Old 30-04-09, 05:09 PM   #6
ukgooner
R&G fitting instruction
http://www.rg-racing.com/Images/Prod.../pdf286_83.pdf
Hamicad
http://www.hamicad.co.uk/SV_Fender.html
Or, using the sv650.org link above use the FAQ section there is a link where someone has made their own TailTidy, may be of use.
Old 30-04-09, 06:27 PM   #7
sfy
I don't know if this is going to help or not. I just fitted a tail tidy to my K8 without instructions.
Basically I needed to remove the riders seat and rear plastics to get access to the "snow shovel". You'll find thats held on by 4 bolts and my tail tidy was a straight swap, although there is a bit of a gap which is apparently normal.
You'll need Allan keys, a socket set and a screw driver to get those annoying plastic rivet things off (I broke a couple when I did it, but I am ham fisted)
Took me a couple of hours altogether.
I know its a vague description but if you have any questions feel free to ask
Old 01-05-09, 07:29 AM   #8
Geoffrey
the motrax product is a universal fit isn't it? think you will need to modify it to suit your bike, best to get a tail tidy that is designed for the sv if you are not too good at cutting and drilling.
Old 01-05-09, 01:33 PM   #9
zigrat
I bought an rrse end as well then figured I could not fit it. Took it back and bought a Hamicad. Have to say it was a good decision as the hamicad was real easy to fit and the instructions were spot on..
Curvy tail skirt or tail tidy mouldy Stuff Wanted 3 21-02-09 12:49 PM
My **** - tail tidy Wideboy SV Talk, Tuning & Tweaking 121 01-09-08 06:10 AM
tail tidy joy! kwak zzr Bikes - Talk & Issues 21 12-08-08 09:38 AM
Tail Tidy. Tail Tidy...Sell me your Tail Tidy.... 1world2wheels Stuff Wanted 7 15-07-06 10:09 AM
k4 tail tidy joe650s SV Talk, Tuning & Tweaking 4 24-01-06 09:09 AM
