Old 04-05-09, 03:06 PM   #1
jimmy
Default Electrics completely gone haywire. curvy y2k
I went to ride my bike to work yesterday, as soon as i turned on my lights (main beam) everything went to s***. all 4 indicators come on instead of the main lights, when indicating the front indicators do the opposite to where i want to turn e.g. i indicate left the rear indicator flashes left and the front one flashes right?. the pass button makes all four indicators come on the same happens when i press the the horn. when i have the switch gear set to main beam the display turns off the rev counter and speedo read 0. also when i have it set to side lights or lights off and i indicate the speedo and revs read 0 and the main display keeps turning on and off as does the side light on the front.
any advice please help before i kick the F***ing thing over.
Old 04-05-09, 03:48 PM   #2
maclovin
Default Re: Electrics completely gone haywire. curvy y2k
water in switches??
Old 04-05-09, 03:55 PM   #3
Biker Biggles
Biker Biggles's Avatar
Chaffed wiring loom?There are a number of pinch points in the loom where damage can occur.Round the headstock is one,and under the rider seat is another.Here the bolts that secure the seat can protrude into the loom.Also under the rear seat where the loom kinks around the subframe.As yours seems to be switchgear related Id look around the headstock first.
Old 07-05-09, 04:03 PM   #4
jimmy
fixed itself last night then broke itslef again. checked switch gear nothing. think it's a dodgy connection(s) gonna strip the front saturday.
Old 07-05-09, 08:50 PM   #5
gettin2dizzy
Sorry I can't help. But that's frickin hilarious!
Old 07-05-09, 09:12 PM   #6
Bad earth somewhere I reckon
Old 07-05-09, 09:16 PM   #7
Grinch
Yep look at the loom as it runs from the back lights to past the battery (panels off) as it tends to rub along there too.
Old 07-05-09, 11:53 PM   #8
Nicky S
Nicky S's Avatar
well at least you have hazrd lights when u brake down :P
id say look at the loom were it goes into the back of the head light to start with
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 08-05-09, 11:47 AM   #9
vardypeeps
Seems like some wires on your front loom might have worn and be contacting each other?
You will just have to check everything unfortunatly
Old 08-05-09, 06:41 PM   #10
jimmy
found time to strip it today checked every wire in the front half of the bike sprayed everything with gt-85. so far seems to work ok.
Newbie- completely and utterly! sexyhellbeast Guildford Massive 16 18-05-09 05:36 PM
Sky+ box gone haywire............ Gromit! DarrenSV650S Idle Banter 30 13-02-09 01:01 PM
Apparently I am completely sane… Dangerous Dave Idle Banter 11 31-10-08 07:04 PM
And now for something completely different!!! Caddy2000 Idle Banter 5 06-12-06 08:35 PM
Completely Unrelated To SV Chat curryhound SV Talk, Tuning & Tweaking 4 01-01-70 01:57 PM
