Old 06-05-09, 01:06 AM   #1
2whelltraveler
Default Dead 02 SVS
Need some help on this one. On a 200 mile road trip, bike ran great at first. Stopped mid-way for some lunch, came back out and the bike was hesitant to start but did. I likened it to the hot day killing the battery a bit and pushed on. About 40 miles later, the bike just stopped running (I was doing 75 at the time). No backfires, no pops... just rolled to a quiet stop.
After some investigation I found the wires to the light assembly that come through the renegade aftermarket undertray had the insulation scraped off and they were touching. It smelled strange under the seat... and I could hear the battery gurgling.
Turns out whatever the short killed, in turn killed the battery completely. It was barely a year old. I have confirmed that the bike is not producing spark but will turn over and gas is hitting the cylinders just fine.
Anyone have any ideas as to what component may have "burned up" from this short and how to test it? All the fuses are good.
Thanks for any help you can offer.
Old 06-05-09, 02:10 AM   #2
rictus01
rictus01's Avatar
Default Re: Dead 02 SVS
I'm presuming here,but given the use of the word gas and time of your post you're from across the pond ? ( might be an idea to put your location in your profile).
Greetings.
back to basics here I'm afraid, if as you say the engine turns over on the button at least the starter solonoid and relay are working, but no spark will require a test of the coil feed wires from the ecu to both the front and rear coils ( are both non sparking ?, check also where the loom goes around the rear subframe as it's a known issue), you may well find the side nearest the frame beared as well ( lift it away from the frame to see properly), if you meter the wires out and they appear to be both good, but still no feed, then you'll need to either borrow another ECU to test or buy a new one.
if you have feedto the coils but still no spark then it's either coils/ht leads or plug caps ( but both going at once is unusual).
I'd check the other circuits to be sure and also the headstock loom as this to is a known issue, the manual also specs out a reg/rec test, this would also be wise if as you say the battery has been boiled.
HTH
Cheers Mark.
Old 12-05-09, 01:14 AM   #3
2whelltraveler
OK, I just got some time to look into this again... so I found a part that looks suspect, but I can not find any documentation on what it is. If you look at the pics, it looks like the rubbery covering has melted over the top of a couple capacitors and heat sinks. This is the first electrical component in line with the short from the lights at back of the bike.
Anyone know what it's called, part # to use for replacement or how to test it?
http://picasaweb.google.com/lh/photo...eat=directlink
Old 12-05-09, 01:22 AM   #4
Thats the black box for the ignition. Sometimes referred to as a CDI.
Old 12-05-09, 01:25 AM   #5
rictus01
rictus01's Avatar
the part you show in the pics is part number 32900-20F10 and called the "IGNITER ASSY" or known as the ecu.
Cheers Mark.
It's dead. Red ones SV Talk, Tuning & Tweaking 10 26-01-09 10:09 AM
dead sv hlaf_lyfe Bikes - Talk & Issues 15 26-01-08 09:52 PM
Dead Can? M65 SV Talk, Tuning & Tweaking 19 09-05-06 12:12 PM
HELP - Dead SV Roy650s SV Talk, Tuning & Tweaking 17 01-03-06 08:37 PM
Not quite dead... but definitely ill andyaikido SV Talk, Tuning & Tweaking 0 25-02-06 04:31 PM
