Old 08-05-09, 03:13 PM   #1
Baph
Default Ask the Geeks (code collaboration)...
I'm after a code collaboration system with a web interface, do any of you know one that's free?
Requirements:
-PHP5.
-If it needs a DB, MySQL5+.
-Linux (therefore runs under Apache HTTPD).
TIA.
Old 08-05-09, 11:21 PM   #2
lukemillar
Default Re: Ask the Geeks (code collaboration)...
Requirements:
-PHP5.
TIA.
Think you even out geeked the .org there, Baph!
Old 09-05-09, 06:47 AM   #3
Baph
It looks like it mate, but I've just opted to use phpCollab & "modify" it to suit purpose.
Old 09-05-09, 10:19 AM   #4
timwilky
timwilky's Avatar
have a look at mindquarry, I am not sure as to its development plans lately
Not Grumpy, opinionated.
Old 09-05-09, 08:58 PM   #5
lazymanc
Code collaboration? Do you mean like a bugtracker / dev project management app or a source control management tool?
Dev manangement / trackers:
We use Trac at work but that's Python based (and a bit of a mare to install last time I did it).
Jira is supposedly excellent but not free (and Java based).
Source Code Management:
Obvious ones are Subversion (SVN) and GIT. SVN is centralised (you have a central store and everyone commits to it, with only the most recent changes stored locally) and GIT is distributed (everyone has a full copy of the entire history of the project stored locally).
lazymanc is offline   Reply With Quote
Old 09-05-09, 09:07 PM   #6
Baph
Cheers Tim, I've got a solution to the problem now, but MindQuarry will be used for something else.
Both in one, not asking for much am I?
Trac & Jira are more issue/ticket tracking applications. SVN/CVS/GIT would require a seperate web interface.
Not that I'm picky.
Anyway, what I've done is setup phpCollab (Project Management/Tasks), which has an interface ready for Mantis (Bug/Support ticket tracking system). I've then used phpCollab's update routines to hack in SVN for documents within the entire job lot.
All of it has a single signon, uses the same DB schema, and is relatively secure. My colleague was pretty impressed I'd managed to go from nothing to completely operational in about 3 hours.
Old 09-05-09, 09:14 PM   #7
Kinvig
Previously I've used the Joel on Software bug tracking product....
and Source Gear Vault....
and Visual Source Safe.....
not that that'll be any use to you....
Old 09-05-09, 09:35 PM   #8
lazymanc
Both Jira and Trac have repository browsers for SVN/CVS built in, not sure if they do GIT yet though.
GITHUB has a lot of good press at the minute but I've yet to use it.
Old 10-05-09, 12:48 AM   #9
Holdup
Why is it that i should know about this stuff but every time i read what you are on about it baffles me? doesnt college teach me anything now days? tsssk
Old 10-05-09, 01:26 AM   #10
lazymanc
Why what course are you doing holdup?
There's nothing complex to it really, they're just bits of software that keep a history of changes to your code.
geeks- help me Quiff Wichard Idle Banter 24 30-01-09 11:27 AM
Any IT geeks in here Cam_73 SV Ecosse 18 29-02-08 05:15 PM
So then Geeks Viney Idle Banter 4 06-08-07 11:21 AM
Only for the geeks falc Idle Banter 13 08-02-07 06:21 AM
Something for the geeks.... Baph Idle Banter 81 16-11-06 04:46 PM
