Old 09-05-09, 11:13 AM   #1
slloyd
Default Rebuilding Front End - 2002 Curvy
Right, with the delivery of parts purchased thanks to Huskey, I'm wanting to know if I can replace the top bolt on the forks received.
The picture on the left is my old top bolt, and the picture on the right is the current top bolt in the replacement forks.
Can I just replace these bolts without fuss...?
Thanks.
Old 09-05-09, 11:40 AM   #2
Default Re: Rebuilding Front End - 2002 Curvy
Yeah but there's a solid washer you need to swap as well (so the adjuster has something to press!)
Old 09-05-09, 02:48 PM   #3
slloyd
yc...just looked at the Haynes Manual section 6-11 and I see what you mean.
So as long as I place the following items:-
20 - Top bolt
21 - O-ring
22 - Solid Plate
... all should be well then?
Old 09-05-09, 03:45 PM   #4
Yup it will be obvious when you look at it what is changed.
Old 10-05-09, 12:20 PM   #5
slloyd
Quick Question: Need to get the trolley jack under the ender mount, but seeing as my bike is resting on the front ehaust pipe without Geoff Capes available to lift the front end up in order to slide the trolley jack in - any other weedy ways to get it up in order to get the jack in.
Old 10-05-09, 12:22 PM   #6
Geoffrey
replace the existing washer with a solid one, i believe i read on here somewhere you need to cut the original spacer down too.
Old 10-05-09, 12:43 PM   #7
slloyd
Any idea how I can get the front end up on my own, in order to get the trolley jack in to keep it jacked up?
Old 10-05-09, 02:03 PM   #8
Nicky S
Nicky S's Avatar
when i did this i made my own little stand out of wood.
2 get mine up on the stand i had me and a mate to lift it and some one to push the stand under the bike
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 10-05-09, 02:53 PM   #9
davepreston
could you not jack it up in stages from a different point get 4x4 wooden length from neck to jack jack it up an inch put some wood under then reajust and repeat
Old 10-05-09, 03:23 PM   #10
A step ladder and a ratchet strap
Exhaust Front Pipe Removal Help - 2002 Curvy slloyd SV Talk, Tuning & Tweaking 6 13-05-09 02:32 PM
2002 front subframe and others fitz2007 Stuff Wanted 2 27-12-07 02:42 PM
Front end 2002 curvy stumpy SV Talk, Tuning & Tweaking 8 13-07-06 08:47 AM
2002 K Series GSXR 600 Front Suspension setup parts for SV! Ter For Sale - SV's and SV related items 0 06-07-06 05:52 PM
SV650s 2002 Front Forks (pair) Madtone Stuff Wanted 1 18-01-06 01:19 PM
