10-05-09, 07:25 PM | #1 |
leaking petrol.
further to my previous thread http://forums.sv650.org/showthread.php?t=130283 i know have a differerant problem, filled the bike with fuel today for the first time since doin the work and petrol leaked from the overflow/breather pipe(right hand side of bike by the oil filler) thought i had overfilled the tank but it didnt stop!managed to ride bike home again a journey of approx 40 miles, when i got home tank was nearly empty again!!the fuel was still leaking. could i have damaged the inside of the tank when shaking it to clean it? if so can it be fixed or do i need a new tank?
10-05-09, 07:30 PM | #2 | |
Re: leaking petrol.
See if you can get a rod through it. If so you should be able to feed a pipe through covered in epoxy to seal it.
10-05-09, 07:31 PM | #3 |
Re: leaking petrol.
The filler well drain tube is broken inside the tank.
Do a search and you'll find a fair bit of info on this - I suspect cleaning the tank may have been the straw that broke the camel's back
Leaking Petrol | Stevetmanchester | SV Talk, Tuning & Tweaking | 7 | 31-05-08 05:18 PM |
Leaking petrol after a drop | ranathari | SV Talk, Tuning & Tweaking | 5 | 28-04-08 05:58 PM |
Leaking petrol cap | jonny-zero | SV Talk, Tuning & Tweaking | 10 | 30-04-07 08:04 PM |
Leaking petrol tank | toffo | SV Talk, Tuning & Tweaking | 19 | 24-06-06 03:44 PM |
petrol leaking from breather pipes. | kjames | SV Talk, Tuning & Tweaking | 5 | 14-03-06 08:19 AM |
