Old 11-05-09, 07:44 AM   #1
rallyjon
Default brakes
I've got a sv650s with gsxr front end and six pot calipiers with braided lines but brake has long travel so could someone advise on what size brake master cylinder is fitted on the gsxr.
cheers Jon
curvy lowers for sale on ebay and some other bits
Old 11-05-09, 11:37 AM   #2
Geoffrey
Default Re: brakes
gsxr have the same as the sv, expect when the gsxr went radial i believe
Old 11-05-09, 11:37 AM   #3
vardypeeps
Default Re: brakes
Sure it's not just air in the system?
Old 11-05-09, 12:15 PM   #4
Default Re: brakes
If the pistons are not clean, the dust seals will drag and pull the pistons too far back into the caliper.
Is the lever hard once it has taken up excess travel?
Which 6 pots are you using? The 'busa ones or GSXR1000 ones?
Old 11-05-09, 09:29 PM   #5
rallyjon
Default Re: brakes
No air in system and seeing as same size cylinder I think I will overall calipiers with new seal kits.
thanks for all your help Jon
Old 11-05-09, 09:31 PM   #6
Default Re: brakes
Keep the seals, just try strip, clean and reassemble with some rubber grease.
Old 11-05-09, 09:31 PM   #7
rallyjon
Default Re: brakes
Think they are the gsxr one's, didn't buy them myself I bought the bike in bits on ebay last year.
cheers Jon
Old 11-05-09, 09:32 PM   #8
rallyjon
Default Re: brakes
Will try that first at weekend thanks Jon
Old 11-05-09, 09:36 PM   #9
Default Re: brakes
GSXR750 96-99/'busa/'TLR/ZX6R
GSXR1000K1-K2 #not certain match# but that shows the different shape with the bottom mount much closer in to the pistons and not having the triangular profile.
Old 11-05-09, 09:58 PM   #10
rallyjon
Default Re: brakes
gsxr 750 one's cheers
brakes / oil lapchick = mad hungarian Ancillaries 4 03-03-07 03:03 PM
Brakes Hogzi Stuff Wanted 0 06-03-06 08:47 PM
Brakes ! stewboy SV Talk, Tuning & Tweaking 3 19-12-05 04:55 PM
Brakes JakeRS SV Talk, Tuning & Tweaking 7 13-04-05 12:15 PM
Brakes - Help! Yokel SV Talk, Tuning & Tweaking 7 11-04-05 08:17 PM
