Old 14-05-09, 04:47 PM   #1
suzuki badboy
Default Air filter
Hello,i need a new air filter,i have a k5 650s with a micron end can.Which air filter should i go for?thanks for any suggestions
Old 14-05-09, 04:57 PM   #2
Default Re: Air filter
OEM unless you want to mess about a lot
Old 14-05-09, 05:10 PM   #3
suzuki badboy
oem,whats that origanal equipment
Old 14-05-09, 05:17 PM   #4
Yes
Old 14-05-09, 05:21 PM   #5
suzuki badboy
What sort of messing about are you talking about.Cant i just stick a k and n filter in it.would it cause a lot of bother?
Old 14-05-09, 05:23 PM   #6
K and N would cause the messing around!
With an OEM filter it will just act same as it did before without a rejet/remap possibly required.
K+N might make a "road" filter that flows the same, so it's just like an OEM but washable. Maybe worth a go if you do lots of miles.
Old 14-05-09, 05:32 PM   #7
suzuki badboy
I wouldnt really do a lot of miles,so ill just go for the origanal.Btw im going to get the micron cut down a bit,will this cause any problems?
Old 14-05-09, 05:37 PM   #8
Nah not really, lose a little bit of midrange, but I don't expect this would be noticeable on the stock pipework.
Old 14-05-09, 05:43 PM   #9
unless you plan on doing megaaaaa miles and keeping the bike for years and years stick to OEM..
http://shop.wemoto.com/pictures.dyn?u=5835676qqq25656
the K&N one is £44 the stock one is £16 so you would need to do 25000 miles before you see any cash back on the K&N plus you still need filter oil and petrol to clean the K&N so there is another £10...
the stock filter is good enough and will do up to about 10000 miles before needing changed...
you are not going to 'feel the difference' out of a K&N or like unless you have a rolling road session... and even then i doubt you would notice the gains...
Old 14-05-09, 05:53 PM   #10
suzuki badboy
Thanks very much guys
K&N Air Filter markryker SV Talk, Tuning & Tweaking 11 29-03-09 09:08 PM
K&n Air Filter lancasterlad Ancillaries 12 23-11-07 04:24 AM
K&N Filter Phantomtek Stuff Wanted 1 25-04-07 05:48 PM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
