Old 16-05-09, 11:53 AM   #1
speedplay
Default Sticking stainless mesh to plastics
As the title says, what would you use to stick stainless steel mesh to the insides of the plastic lowers?
I have a fair bit of 4 inch stainless insect mesh left over from a job I did a few years back and decided to tidy up the gaping great holes in the sides of my lowers.
I know I will have to remove the lowers to do this but not sure what to use to stick it with though.
I did think about using Araldite or something like plastic padding but wanted some feedback.
Cheers guys.
Old 16-05-09, 11:57 AM   #2
Sally
Default Re: Sticking stainless mesh to plastics
Glue gun if I remeber correctly.
Old 16-05-09, 11:59 AM   #3
sweepdoggydog
I've done it before using a glue gun
Old 16-05-09, 11:59 AM   #4
drag
Very interested in this, must go get some silver or chrome bits my self.
Old 16-05-09, 12:10 PM   #5
Stu
Trinity
Stu's Avatar
But if he doesn't have a glue gun, why would araldite not work?
That's very fine (restrctive) mesh. Would it make the radiator run hot?
Old 16-05-09, 12:15 PM   #6
speedplay
I cant see it affecting the radiator to be honest as its back behind it and theres a massive gaping hole on the front where the rad is. (Thats next to be filled in but with a stiffer and wider mesh.)
Old 16-05-09, 12:18 PM   #7
drag
The idea of fitting some mesh to the front of the bike might just restrict the removal of the fairings, i know on the curvy you have to remove the bolt at the bottom of the rad to get them on/ off, not sure about a pointy, but i'd like to see the end product.
Old 16-05-09, 12:34 PM   #8
mackrilld
Good thread i was only just the other day thinking about how i could fill those holes up with mesh and it seems to be a glue gun will be the best idea
Old 16-05-09, 02:42 PM   #9
speedplay
Old 16-05-09, 02:47 PM   #10
Geoffrey
i think the post was about the air escaping the radiator, these side vents are for the hot to pass out of and not for the cold to run through.
been fiddling with mesh again Quiff Wichard Photos 20 09-04-08 04:57 PM
Mesh and rim tape John 675 Photos 8 29-02-08 01:11 PM
Better pictures of Mesh bikerskez Photos 3 03-03-07 09:34 PM
wire mesh bikerskez SV Talk, Tuning & Tweaking 3 04-02-07 11:45 AM
Mesh Mod Richie Bodywork 4 23-05-05 03:45 PM
