Old 17-05-09, 03:20 PM   #1
Blue Flame
Blue Flame's Avatar
Default K3 Drain plug. Diameter & Pitch?
I have succesfully managed to strip the internal thread of the sump casing when tightening up the drain plug during an oil change.
I was going to have a go at repairing with a 'heli-coil' ?
1 - Is this the best way to go about fixing it?
2 - If so what size kit do I need to get?
And yes I know I am a numpty for overtightening.
Triumph Sprint GT 1050 -Sexy Phantom Black; Powerbronze Screen
Previous >> K3 SV650S - Candy Copper;Lower Fairing Set;Fender Extender; Powerbronze Screen; HEL Braided Lines;
Blue Flame is offline   Reply With Quote
Old 17-05-09, 03:33 PM   #2
Default Re: K3 Drain plug. Diameter & Pitch?
well done blue...
you would be better off getting a different (bigger thread) sump plug and tapping out the sump... its a bit more fiddly but its the best bet... i think i have some big taps in the workshop i'll check next week..
anyone know what size the sump plug is on a pointy?
Old 17-05-09, 08:54 PM   #3
thefallenangel
14mm socket will probably be a 10mm thread metric. 7/16" tap if you can get one with a 7/16" thread bolt.
Old 17-05-09, 08:55 PM   #4
It's fine pitch IIRC
I will measure up when I get some time
Old 17-05-09, 08:57 PM   #5
Blue Flame
Blue Flame's Avatar
I have discovered from the manual it's an M12.
Just nbeed the pitch size or does that matter as long as I get a drain plug to suit the pitch?
Old 17-05-09, 08:59 PM   #6
thefallenangel
plug will need to marry up with the thread inside the coil or tapped out thread.
Old 17-05-09, 09:00 PM   #7
could always just get a 13mm bolt and cut it down then tap new hole to 13mm easy peasy...
that is unless you really want the magnetic bit on it... you could try halfords.. they do a nice range of sump plugs..
i'm sure we have some 13mm bits in the workshop...
Old 17-05-09, 09:05 PM   #8
If it were mine I would rather do it properly with a replacement sump plug with the fine pitch. Helicoil is not a hard job.
Old 17-05-09, 09:10 PM   #9
Blue Flame
Blue Flame's Avatar
I think that's what I would prefer to do but I cannot for the life of me find anywhere on line that tells me the pitch size.
Helicoil kits for M12 seem to come in pitch sizes of 1.0, 1.25, 1.50, and 1.75 mm so I am stumped for now.
Old 17-05-09, 09:11 PM   #10
Give me 5 minutes
Air Cleaner Drain Plug phizog SV Talk, Tuning & Tweaking 11 30-12-07 07:36 PM
Oil Drain Plug seized and rounded aliman2000 SV Talk, Tuning & Tweaking 21 10-09-07 04:15 PM
Problems removing oil drain plug Valman SV Talk, Tuning & Tweaking 14 18-06-05 09:26 AM
where is the coolant drain plug?? hall13uk SV Talk, Tuning & Tweaking 34 25-05-05 04:25 PM
Oil drain plug- Help. Peter Henry SV Talk, Tuning & Tweaking 7 17-10-04 01:26 PM
