Old 18-05-09, 12:20 PM   #1
RichT
Default Which LED Bulb?
Quick question for the collective.
Is there a std LED "bulb" that can be plugged staight into the sidelight fitting of a pointy?
I'm thinking of switching my front OEM indy's for flush mounted LED's (fitting into the fairing recess) and I know I'll need a recifier(?) if putting LED's in. I'm just wondering if it's a simple thing to change the sidelights at the same time.
Old 18-05-09, 12:35 PM   #2
The Guru
Default Re: Which LED Bulb?
I've got LED sidelight bulbs on mine
Seemples
Old 18-05-09, 12:35 PM   #3
SoulKiss
SoulKiss's Avatar
Yes.
Goto Ultraleds I have these on my Zed
Old 18-05-09, 12:35 PM   #4
maff
yes i have white ones in mine. so long as its the 501 you should get some pretty much anywhere
Old 18-05-09, 12:38 PM   #5
RichT
Thanks for the replies - I'll take a look at Ultraleds...
Should have mentioned I intend to have the sidelights as front facing indy's, so a little adjustment to the wiring will be required. Anyone got any advice on that? i.e. blanking the current wiring etc.
Old 18-05-09, 12:40 PM   #6
The Guru
Yes 501 bulb type
Which bulb for the headlight? James SV SV Talk, Tuning & Tweaking 4 05-04-09 12:17 AM
HID bulb life Neil63 SV Talk, Tuning & Tweaking 2 03-10-08 11:46 AM
indicator Bulb 'help'!! Blue_SV650S SV Talk, Tuning & Tweaking 23 12-07-07 08:48 AM
Bulb fittings Jester666 SV Talk, Tuning & Tweaking 2 22-05-07 07:57 PM
bulb out ?????? dougieo Bikes - Talk & Issues 0 16-09-06 08:29 AM
