Hi,
After getting the current one bent, I was hoping to get it replaced with something easier to control as I'm finding the position of the pedal not comfortable and it's proving hard to apply proper controlled pressure to it using my heel on the footrest as a pivot. If anyone is aware of replacement pedals that might be more comfortable to use, I would appreciate any information on the subject. Thanks Uri |
The OEM pedal has some height adjustment at the bolts to the MC at the back, but I guess that won't help if you can't reach it!
Thanks, I can reach it but can't comfortably keep my foot in the right position to operate it smoothly. Do you have a link to the OEM company?
Cheers U. |
OEM means Original Equipment supplied by Manufacturer!
![]() Is the pedal too long for you? You could always measure how much shorter you want it and get it altered by anyone that can weld Aluminium. There is a couple of companies by me that specialize in metal work and fabrication. Angel Weld, based in New Addington, Croydon. OR Limpsfield Engineering Ltd Unit 10 &11 Airport Industrial Estate Wireless Rd Biggin Hill Kent TN16 3BW Both are really good and helpful. Dave |
Thanks Dave!
(Embarrassed grin) aah OEM = Suzuki. It might be too long, I'll have a play, cheers for the advice. U. |
99-02 rear brake pedal | Marcus | Stuff Wanted | 17 | 14-04-09 07:27 PM |
rear brake pedal? | seano | Stuff Wanted | 0 | 12-04-07 07:29 PM |
Rear Brake Pedal | 01 sv650s | Stuff Wanted | 1 | 29-03-07 10:11 PM |
Rear Brake Pedal | 01 sv650s | Stuff Wanted | 0 | 29-03-07 07:59 PM |
Rear Brake Pedal | teknovision2 | Stuff Wanted | 1 | 24-07-06 06:21 PM |
