Old 19-05-09, 08:24 PM   #1
davepreston
Question Fork removal help
could one of you lovely people (getting the sucking up in early) tell me the easyest way to remove the forks if i need any special tools or any genral points pit falls i should be aware of
hopefully it wont be a mare to do forks and yokes are the only bits that need to be seperated upon removal. so line up below to call me a muppet throw abuse then give me the answers i require
cheers dave
Old 19-05-09, 08:26 PM   #2
simesb
Default Re: Fork removal help
Release the clipons and top-caps before undoing the clamps - makes life a bit easier
Old 19-05-09, 08:33 PM   #3
skeetly
skeetly's Avatar
Abba stand.
Then small bottle jack under the fron down pipe to tip the bike onto the back wheel.
I think you need a 12mm allen key for the front wheel spindle. I never had one in my tool kit.
Remove the front wheel, fender.
Take off the calipers and use some string to hang them carefully from some handy bit of the bike.
As mentioned above slack off the cap bolts on the top of the forks and the clip on bolts.
Slack off top yoke pnch bolts.
Undo the bottom ones one at a time and slide the forks out....
Thats from memory and mine was pointy.........
skeetly is offline   Reply With Quote
Old 19-05-09, 09:58 PM   #4
Nah you don't need an allen key for the curvy.
Crack the top caps before you split owt else. Rest isn't too bad.
Sticker removal - how? Jack The Kipper SV Talk, Tuning & Tweaking 11 08-09-10 03:54 PM
GSXR front fork end cap removal? tactcom7 Bikes - Talk & Issues 3 17-09-08 01:36 AM
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
