Old 21-05-09, 04:01 PM   #1
Grinch
Default Org shim swap service.
After talking to Mark last night it was bought to my attention, that some shops do a shim swap service so you get cheaper ones if you trade a old shim in.
Now I know that a number of other people have done their shims on there SV's, though I'm not sure if there is a difference between curvy and pointies but I don't imagine a reason why there would be.
So maybe we could set-up some sort of shim swap service between us all.
Just tell us the size of the shims you have and then people can swap. After all what you going to do with your old shims? And you have not idea what shims your going to need next time, but if you have a set to swap its all nice and easy to do here.
Just a idea... foo, foo me if you wish.
Old 21-05-09, 04:05 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Org shim swap service.
So "Shim Swap Shop"
You WILL have to grow the Noel Edmonds beard you know........
Old 21-05-09, 04:11 PM   #3
RatchetJob
Grinch,
Good idea, i'd be up for it I'm going to do my clearances soon so I'm sure I'll have (and need) a few shims to swap.
Old 21-05-09, 07:57 PM   #4
TSM
The Sick Man
TSM's Avatar
Good idea, it wont work though.
People will end up with shims they will never use.
Look at Zoom Factory, cheep shims.
Old 04-06-09, 09:05 AM   #5
Grinch
Oh well I'll have a look at that then.
Old 04-06-09, 02:14 PM   #6
flymo
flymo's Avatar
they cost peanuts from a bike garage/dealer. Its not often they need changing on an SV anyway.
Valve change & tappet (shim) check. rictus01 SV Talk, Tuning & Tweaking 10 08-11-10 12:39 PM
valve shim diameter erik SV Talk, Tuning & Tweaking 3 16-06-08 08:00 AM
Done Re-shim - now worried about starting it!!! mattb200 SV Talk, Tuning & Tweaking 35 01-05-08 01:35 PM
Do i have to rejet or shim raven22 Exhausts 4 10-02-06 12:47 AM
Shim the Carbs Needles TSM SV Talk, Tuning & Tweaking 3 25-07-05 11:26 AM
