Old 23-05-09, 08:38 PM   #1
slloyd
Default Expansion Chamber...Coolant not Draining
I have carried out a search of this, and found a simular post, but not the problem I am experiencing.
Fom yc in the seached thread was, IIRC the drains are all tee'd in and go down by your right heel.
Well when following another How to: Thread, it tells you to pour distilled water doen the expansion chamber, and the to remove the hose from the radiator and drop below the level of the chamber, in order to flush the chamber out of any old cooland left behind.
When I do this, the water just fills straight to the top of the expansion tank, and does not come out of the hose at the bottom.
Could the hose be blocked at the bottom of the chamber?
Old 24-05-09, 01:17 PM   #2
Default Re: Expansion Chamber...Coolant not Draining
Yes it could be blocked/kinked. You have taken small hose off radiator neck right?
Old 25-05-09, 04:33 PM   #3
slloyd
Yes I have yc, it's point 13 in this link http://forum.svrider.com/showthread.php?t=54075 I don't get anything draining from here.
If I pour water into the chamber would expect it to run out of this hose. No kinks in the hose at the lower end.
Old 25-05-09, 06:15 PM   #4
Blow into the hose (don't get a gobful of coolant, it's nasty)
Might be kinked at the bottom of expansion tank.
Old 25-05-09, 06:30 PM   #5
Oh yeah regarding that writeup. I've always found it far easier to avoid fishing around in the drain pan by the simple expedient of not dropping the drain plug in there.
Old 25-05-09, 06:39 PM   #6
zadar
disconnect hose from bottle and clean hole in it, it gets clogged like yorkie said.
Old 25-05-09, 09:36 PM   #7
slloyd
Yeah, that part is easily avoidable not sure why the narrator would let that happen.
Will double check the hose in the morning, and look to taking the hose off to see if it is blocked with old coolant.
Old 25-05-09, 09:41 PM   #8
It's some wierd white crap that accumulates. I haven't had a problem with it since using OAT coolant diluted with distilled water, presume previous owner of mine used hard water. (think scale on kettle) as it turned the expansion tank white also.
Old 26-05-09, 12:08 PM   #9
slloyd
yc, right once more, managed to unblock with a nail, and now I have filled up with new fluid. Thanks again.
Draining Coolant lazymanc SV Talk, Tuning & Tweaking 5 12-05-09 12:09 PM
Expansion Bottle overfill metalmonkey SV Talk, Tuning & Tweaking 7 22-12-08 10:58 AM
Battery draining - Help PaulyMac SV Talk, Tuning & Tweaking 19 01-06-07 09:30 AM
Carb Float Chamber HopefullySoon Stuff Wanted 1 01-06-06 11:40 AM
M1 Lane Expansion Warning - SPECS Cameras PsychoCannon Idle Banter 25 08-05-06 01:45 PM
