Old 26-05-09, 10:12 PM   #1
Holdup
Default Siezed rear caliper?
About 1500 - 2000 miles ago i replaced my rr pads with some normal EBC ones as one of my pads had worn more than the other, i have now noticed that my rr pads have worn more than half, now i do use my back brake a lot but surely they shouldnt have worn out in the mileage i have done, i have stopped using my rear brake unless in slow traffic or filtering but they seem to look worse, my rr disk is also wearing out as well, i have noticed that some times the bike seems like it isnt pulling as well, could it be that they are sticking? I will get the caliper off tomorrow and have a look just after a bit of knowledge and advice really.
Thanks
Old 26-05-09, 10:32 PM   #2
Jamiebridges123
Default Re: Siezed rear caliper?
Isn't that just a strip them and wire brush the pistons and bung em back in thing?
Old 26-05-09, 10:35 PM   #3
Take it in bits, only one piston so nice and easy. Clean it all up, I don't use wire brush on the piston just brake cleaner and scotchbrite.
Old 26-05-09, 11:27 PM   #4
rictus01
rictus01's Avatar
Indeed a wire brush on the caliper body perhaps, once the seals are removed, but don't use a wire brush on the pistons, As Chris says a scotchbrite pad if you must and made the strokes around the piston and not along it.
Cheers Mark.
Old 26-05-09, 11:34 PM   #5
Holdup
Cool thanks, will look tomorrow, whats the worst? new seals?
Old 27-05-09, 10:21 AM   #6
branny
yes, i would expect that with new seals (and fluid) your brake will be 10 times better.
there is a chance that you wont need a new seal, but with it being one piston, i think it will be quite cheap.
http://shop.wemoto.com/pictures.dyn?u=1915475qqq5828001
i am a little confused as to why this 'full rebuild kit' has 2 sets of seals though-
http://shop.wemoto.com/pictures.dyn?u=1915475qqq3689421
i think i need confirmation on the amount of rear seals!!!
p.s. be sure to buy this-
http://shop.wemoto.com/pictures.dyn?k=WE-STUBRED
Old 27-05-09, 10:44 AM   #7
jambo
jambo's Avatar
Hold up!
The rear caliper on the 99-02 bikes was a 2 piston caliper, the ones from K3+ are a single piston caliper and totally different.
(This is why a full rebuild kit for the 99-02 bikes have 2 sets of fluid & dust seals, plus the caliper half joining seals)
Please don't order the above parts, they may well not fit!
For a K3+ bike use http://shop.wemoto.com/pictures.dyn?u=5835675qqq5828001
(Same price and picture, but that's not to say it's actually the same part)
Jambo
Old 27-05-09, 10:47 AM   #8
branny
oops, searched for my bike!
Old 27-05-09, 12:02 PM   #9
vardypeeps
lol
Old 27-05-09, 12:13 PM   #10
branny
i think you will find the grease works for any year.
rear brake pins siezed - what now ejohnh SV Talk, Tuning & Tweaking 31 15-12-08 01:16 PM
Rear Caliper... Grinch Stuff Wanted 5 02-07-08 10:06 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
How do I free a caliper that's siezed onto a disc? monkey SV Talk, Tuning & Tweaking 13 29-03-07 07:17 AM
rear caliper pad pin siezed mec SV Talk, Tuning & Tweaking 12 23-05-06 07:04 PM
