Old 27-05-09, 08:23 PM   #1
airbrush_assasin
Default Suspension set up
Hi , anyone point me in the right direction for a desent basic set up for my suspension, I have a GSXR 1000 K6 rear shock, 25mm jack up, standard forks with hagon progressive and 10 weight oil. Cheers
Old 27-05-09, 08:28 PM   #2
Default Re: Suspension set up
How does it feel now? Or have you just fitted this stuff?
Start by setting total sag to 35mm, put damping adjusters to standard settings for GSXR and go from there.
Old 27-05-09, 08:36 PM   #3
charlie13
is that front or rear sag YC? I thought it was 30-35mm front and about 10-15mm rear static sag
Old 27-05-09, 08:41 PM   #4
Total sag for rear.
Do front preload by cable tie it's easier.
Old 27-05-09, 08:43 PM   #5
airbrush_assasin
Forgot to add I have converted it from S to a naked , I want to know how much fork to leave poking out the top yoke, as a naked K3??
Old 27-05-09, 08:44 PM   #6
Anywhere between flush and about 15mm. I'd go for flush to start with, can sharpen it up later if you want.
Old 27-05-09, 08:45 PM   #7
charlie13
well after checking up on myself I have found conflicting stories from 2 seemingly reliable sources.
Ohlins says one thing (that's the link for curvy rear shock)
http://www.ohlins.com/Products/Owner...M_07241-02.pdf
And white power say another, in the section entitled "A few technical terms explained"
http://wpsuspension.co.uk/setup.php
Old 27-05-09, 09:00 PM   #8
airbrush_assasin
http://www.strappe.com/suspension.html#sag
Just found this one....
Old 03-06-09, 02:28 PM   #9
Holdup
Does the cable tie method work on the SV's standard suspension? right way up forks, i have only seen it done on usd forks im trying to set mine up i understand rear sag but want to know as i have seen the cable tie method, adjusted my front softer seems to tip better into corners sometimes scary but seems to chatter a lot on the straights.
Old 04-06-09, 01:21 AM   #10
lukemillar
Use the Ohlins guide as the WP one rather badly worded. Despite quote % of travel etc, they dion't really differentiate between fork springs a rear shock springs. For instance this:
"The negative spring distance therefore should be between 20 and 40 mm"
That much static sag for a shock is far too much. Ohlins quote 5-10mm which is what I have always learnt to use from many different sources.
Secondly, I find it weird that when WP talk about spring preload - they use it to set ride height? Spring preload is simple. It is how much load is applied to a spring and therefore dictates how much additional load will need to be applied before that spring moves further.
EDIT: Best suspension resource online I have found is here:
http://www.sportrider.com/suspension...ide/index.html
http://www.sportrider.com/suspension...ngs/index.html
Suspension M65 SV Talk, Tuning & Tweaking 28 14-12-19 11:47 PM
suspension when 2 up Draper SV Talk, Tuning & Tweaking 5 08-05-08 10:27 AM
What suspension? Mike2165 SV Talk, Tuning & Tweaking 17 26-09-07 01:11 PM
Suspension Cos SV Talk, Tuning & Tweaking 4 17-05-05 12:26 PM
suspension set-ups . . where ? Warren SV Talk, Tuning & Tweaking 9 06-05-05 06:11 PM
