Old 02-06-09, 01:17 PM   #1
gowiththeflow75
Default MOT failure - rear LED light.
Hi any advice would be appreciated.
I had a fail from the MOT garage, I think its the smallest thing when the engine is running the tail light is fine but when you put the indicator on the top 3 rows fade in and out.
The voltage on the battery is ok 12.9v
Old 02-06-09, 01:19 PM   #2
ricky
Default Re: My Bike failed an MOT help please
earthing problem????
Old 02-06-09, 01:22 PM   #3
fizzwheel
fizzwheel's Avatar
It would be helpful if you told us a little more about the make and model of your bike.
Old 02-06-09, 01:23 PM   #4
philbut
+1
You have a bad connection somewhere mate. First off I'd have a look at the connectors for the rear lights - are they all clean and free of corrosion. if yes, then examine the cables - is there any sign of damage to the insulation that could be causing a short - pay particular attention to points where the cable might rub on the frame etc as this can wear away the plastic shieth after a while.
Old 02-06-09, 01:29 PM   #5
gowiththeflow75
Sv650 K4 I had a look at the connectors all local to the LED cluster all looks fine and clean, I am going to take the rear left hand side plastic bits of tonight and have a look as I can see a few conectors there.. Thinking about it I might just run a cable stright off the battery + - starght to the led's and see what happenes.. ta for the advice
Old 02-06-09, 01:30 PM   #6
SoulKiss
SoulKiss's Avatar
K4's have a problem with the rear lights - new unit required to fix I believe (unit is sealed so tricky to get into to look at fixing).
K5 onwards don't seem to have had this issue.
Old 02-06-09, 01:32 PM   #7
gowiththeflow75
For real has anyone else heard of this problem before !!!
Old 02-06-09, 01:41 PM   #8
Amplimator
i too have had this tail light problem but on my K3. top three led's (both sides) go out upon indicator or brake light/lights being used.
replacement rear light sorted it as all cables/connectors were fine
Old 02-06-09, 01:49 PM   #9
gowiththeflow75
anyone got a spare tail led unit our one going cheap
Old 02-06-09, 01:54 PM   #10
SoulKiss
SoulKiss's Avatar
My original post should have included K3 with K4.
Rear Light plowsie Stuff Wanted 6 09-11-07 04:38 PM
rear light lancasterlad For Sale - SV's and SV related items 1 24-08-07 04:07 PM
Help, Dash Light failure... but not. Grinch SV Talk, Tuning & Tweaking 3 06-10-06 09:44 AM
sv650 99-02 rear light+indicators+numberplate light andyrs For Sale - SV's and SV related items 3 29-09-06 10:59 AM
rear light shearwood SV Talk, Tuning & Tweaking 1 01-07-05 06:50 AM
