Old 02-06-09, 11:14 PM   #1
Default fitting autocom
again in prep for scotland trip.
1. goin to feed it in off the switched live to the rear lights .. do I need to use an inline fuse ya reckon too??
and if so what? 3amp?..
Old 02-06-09, 11:17 PM   #2
madness
Default Re: fitting autocom
Yes fit a fuse. Have you not got any fitting instructions with the Autocom?
Old 02-06-09, 11:28 PM   #3
yea i got the full instructions but I am a numpty.. well I not as bad as I make out- but electrics scares me..
then I am always quite proud of my achievements when I done stuff.
I will sit on the hammock tomorow and have a reet good ole read of the instructions.. worrying splicing the wire to my rear light.. but dont want to just use a pp3 battery and keep replacing with running an mp3 off it too.. ( I hope !)
Old 02-06-09, 11:38 PM   #4
madness
Aren't PP3 batteries 9v? Bikes are 12V
Old 03-06-09, 12:07 AM   #5
dunno mate
maybe its PP9 I dunno- like the one in a smoke alarm
Old 03-06-09, 08:03 AM   #6
Luckypants
Luckypants's Avatar
Yeah the 9V / 12V thing worried me to, but Autocom been using that combo for years and so it must be ok. I was not keen about splicing into wires so mine plugs in to the Optimate lead direct to the battery. This means that the unit is powered all the time it is plugged in, but Autocom informed me that this would not harm the unit - the only thing they wanted to point out was it could drain the battery over time. This method worked well for 16 day tour last year, so not a big issue while the bike is in use. If the bike is not being used, unplug the Autocom and plug in the Optimate, job done.
Old 03-06-09, 09:19 AM   #7
cheers Mike-
I might need to get an optimate lead me thinks
Old 03-06-09, 09:44 AM   #8
Mike-
I can get an optimate weatherproof lead no problem .. but do you getthe other end from to conenct to from Autocomm? or can you buy an optimate male or female plug?
Old 03-06-09, 10:22 AM   #9
custard
have just fitted an active duo. comes with a 9v battery lead and a "loom" for wiring into the bike.
spliced it into the number plate light using bullet connectors and so far no problems.
if you need any parts i reccomend www.chainspeed.co.uk very knowledgeable and fast delivery.
i used the powered ptt loom and keep the autocom, radio mp3 in a tank bag. saves farting around under the seat the whole time.
Old 03-06-09, 11:13 AM   #10
Luckypants
Luckypants's Avatar
you can buy a female plug for it, either from Optimate or from a R/C model shop - it's the same connector they use to charge their toys.
Autocom helmet fitting Miles Bikes - Talk & Issues 7 25-03-09 10:33 PM
Autocom? Nobbylad Bikes - Talk & Issues 17 19-10-08 08:08 PM
Autocom fitting to K3 pepe SV Talk, Tuning & Tweaking 11 23-01-06 12:14 PM
Fitting an autocom thingy on the bike... valleyboy SV Talk, Tuning & Tweaking 3 15-07-05 08:31 AM
Fitting an Autocom system Baldyman SV Talk, Tuning & Tweaking 23 23-06-05 11:02 AM
