Old 07-06-09, 07:51 PM   #1
Toriiii33
Default Fuelling problem?
Hello! I know I don't post very often but I'm quite bad with forums. I was instructed by a member on here to ask if anyone knows what my fault could be.
The bike keeps cutting out. It also doesn't hold the revs when the throttle is held steady. Anyone have any ideas?? It's an '05 SV650S.
Thank you
Tori
Old 08-06-09, 02:46 AM   #2
Jamiebridges123
Default Re: Fuelling problem???
TPS? Run some fuel injection cleaner and some super unleaded?
Old 08-06-09, 03:22 AM   #3
lukemillar
Ok, I'm no mechanic, but I probably wouldn't start off trying any of ^^ that!
Start with the basics. If it runs in some shape or form then you are definitely getting fuel and spark. Stumbling at constant throttle/stalling at tickover could point to either too much or too little fuel or air.
So if it was me, I'd start of checking the airbox/air filter for blockages, then the throttle bodies for balance.
Has it been a developing problem or did just happen one day ot of the blue?
Old 08-06-09, 03:39 AM   #4
Jamiebridges123
Oh yeh check spark plugs. If they're all sooty it's running rich so check fuel air mix..as luke says.
but yeh super unleaded works a treat normally
Old 08-06-09, 07:38 AM   #5
ThEGr33k
1) Has it been stood unused for a while?
2) Whats it ticking over at?
First thoughts for me would be that the Petrol has gone off due to standing and that this is blocking the fuel system somewhere. Very common problem with bikes after storage and it sounds very like the problem your having... though it is less common with injectors.
Old 08-06-09, 08:43 PM   #6
Red Herring
Red Herring's Avatar
My K5 was doing that recently, tried various things but turned out to be a duff TPS. Fitted a new one, job done. Not that expensive either.
Old 08-06-09, 08:45 PM   #7
Jamiebridges123
wot did eye... tell ewes?
Old 08-06-09, 09:04 PM   #8
Red Herring
Clever clogs...!!
Old 08-06-09, 09:16 PM   #9
lukemillar
There are about 10 different things you can check for free, before digging into your pocket to buy replacement parts to further diagnose the problem.
Old 09-06-09, 09:12 PM   #10
Toriiii33
Thanks to everyone for your replies. It's my race bike so I always use super unleaded. The bike was sat for a while with a small amount of fuel in it which may have gone off and sooted the plugs. The wiring loom had somehow got knotted and sections of it were pulled tight which may have contributed somewhat. Changed the plugs and sorted out the wiring loom. It seems to work again.... for now!
Thanks again for your great advise!
Tori x
SV fuelling, air filters etc. metalmonkey SV Talk, Tuning & Tweaking 17 27-10-08 04:22 PM
fuelling up stanie SV Talk, Tuning & Tweaking 16 16-09-08 05:29 PM
Fuelling upgrade? gazza SV Talk, Tuning & Tweaking 1 09-05-08 07:21 AM
Sorting out the fuelling. the_lone_wolf SV Talk, Tuning & Tweaking 9 13-08-07 11:18 AM
Fuelling Problems curium SV Talk, Tuning & Tweaking 2 15-06-06 02:15 PM
