Old 09-06-09, 08:59 PM   #1
forklift
Default Battery life?
Is it reasonable to have a Yuasa YT12ABS battery last 23 months give up even when Optimated regularly? No alarm, no current leakage, no charging problems. I just read another thread where not charging but still connected may drain the power. I have seen a red glow from the optimate ... perhaps this does drain the power.
Old 10-06-09, 05:38 AM   #2
Marcus
Default Re: Battery frustrating me AGAIN...
Optimates are supposed to emulate charging /discharging cycle of a battery under normal use i.e. charge to full capacity, then put a slight drain on then recharge. My ex partner bought her new battery in April (yuasa) & it lasted a whole 4 weeks - she'd have been doing cartwheels to have got 23 months. Then again, I've had them last 5 years without an optimate - go figure.
Old 10-06-09, 05:47 AM   #3
tigersaw
tigersaw's Avatar
Is / was this a battery you fill with acid yourself then seal? If not done correctly, and this includes by many dealers, the batteries fail early on.
Old 10-06-09, 06:40 AM   #4
forklift
filled it properly and then sealed, though i read the yuasa advert last night and before sealing it must be left one hour.
Old 10-06-09, 06:48 AM   #5
tigersaw
tigersaw's Avatar
Until it has gone cold, generally an hour or so yes.
Old 10-06-09, 10:22 AM   #6
forklift
i'm going to leave for a week or so unconnected completly from the optimate and monitor the thing. last thing i want is to get stranded, bumping bikes is another thing all together.
Old 10-06-09, 11:14 AM   #7
Biker Biggles
Biker Biggles's Avatar
Does the Optimate actually charge it properly and give two green lights?Could it be faulty?
I tend to use the Optimate every few weeks and dont leave it connected.Id say 23 months was very poor for a top battery.My OE SV battery lasted 8 years.
Old 10-06-09, 11:58 AM   #8
forklift
Optimate ok as i have 3 and alternate on 3 bikes. Green lights both come on. I had the reg/rec checked by Orwells in Ipswich and that was ok, i checked the 'current leakage' and that was fine. perhaps the battery is poor, but i do not want to buy a new one just yet incase it is not the battery. My VN battery lasted 8 years too.
Old 10-06-09, 02:24 PM   #9
glang
forklift I fear you entering the twilight zone. I too, like many on here (see the threads) have struggled with repeat dying batteries (honda blackbird). Its difficult to prove without hi tec gear (even then its not easy) but I believe the problem was a faulty reg/rec from charging flat batteries (I'll never bump or jump dead bikes again). One phase fails but the output voltage appears normal however the DC has an AC component that frazzles batteries. Maybe a second expert opinion would be useful?
Battery Life When Bike Is Idle Toypop SV Talk, Tuning & Tweaking 9 09-11-05 08:06 AM
Battery Life scousegit SV Talk, Tuning & Tweaking 12 03-07-05 09:31 PM
Battery life when left standing jon SV Talk, Tuning & Tweaking 10 15-04-05 12:14 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
SV wouldn't start. What's the battery life expectancy? RobSV SV Talk, Tuning & Tweaking 22 20-01-05 11:15 AM
