Old 11-06-09, 10:24 PM   #1
Ratty
Ratty's Avatar
Default Fairing lowers bracket
Hi all
I'm after a fairing lowers bracket for my thou so I can have my fairings on for my track day Sat 20/06. I presuming the 6 1/2 is the same as the thou even though the fairings are different but I'm sure you guys will let me know. PM if you can help.
Thanks in advance Alan
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 13-06-09, 06:56 AM   #2
Nobbylad
Nobbylad's Avatar
Default Re: Fairing lowers bracket
Which bracket, the arched one that is replaced by crash bungs (if you get them) or one of the 'u' shaped brackets that bolt to the rad?
Old 13-06-09, 09:24 AM   #3
phil24_7
As far as I'm aware, the though fairings will not fir. Although they look the same, the engine is bigger and the moun ting points aren't the same. 650 bracketry will only fit on the 650 and only mount 650 fairings and the same goes for the thou.
Sorry but I hope this helps.
Regards
Old 13-06-09, 06:21 PM   #4
Ratty
Ratty's Avatar
It's this one. I thought it may be the same bracket with the holes just in a different place on the 650 to compensate.
Old 13-06-09, 07:41 PM   #5
speedplay
Pm me your address and ill take the 2 off my 650 before its collected on monday and pop them in the post.
I know the engine is bigger and the fairings are different...but you may be able to do something with them.
Rob
Old 14-06-09, 10:24 PM   #6
just get it welded.. they are 90 degree. any welder should be able to straighten then weld it back together for you...
Old 14-06-09, 11:13 PM   #7
Ratty
Ratty's Avatar
I am having mine welded but I don't see the guy until tonight and he said it didn't go back to 90 deg when he closed up the break. I'm expecting to have to tweek it again with heat when welded and just wanted something to back it up in the meantime. Speedplay is kindly sending me 650 items to try and if the are different they will be available for the next guy who needs them FOC.
Thanks for the help guys.
Alan
Fairing bracket Ward8124 Stuff Wanted 7 04-05-10 08:14 PM
K4 650S Fairing Bracket RHS DF! Stuff Wanted 5 14-10-08 12:39 PM
SV 650 S 02 FAIRING MOUNTING bracket silver surfer Stuff Wanted 2 29-06-07 08:15 PM
TCP Fairing bracket POGS69 Stuff Wanted 2 11-06-07 09:33 AM
Fairing bracket copper kettle SV Talk, Tuning & Tweaking 0 15-06-06 12:38 PM
