Old 14-06-09, 11:24 AM   #1
beanie79
Default Decent Garages
Quick question.....does anybody know of a decent garage in the chorley (lancs) area?
Basically need new sprockets fitting (long shameful noob story - it has a new chain - 500 miles (not fitted by me) but I've now found out should have new sprockets at same time - ps will the chain be ok or am I going to have to have a new one of those as well?)
Old 14-06-09, 12:17 PM   #2
Dave20046
Dave20046's Avatar
Default Re: Decent Garages
Chain'll be alright (I'd guess! don't hold me to it) just get it done asap. If you shake your chain about does it rattle like a bag of coins? With the chain at the right slack, bike on side stand tug on the chain at the 3 0 clock position on the rear sprocket - how much movement is there? Can you expose a whole tooth, half a tooth? etc.
Sorry I don't know the chorley area can't help with a garage.
Old 14-06-09, 01:04 PM   #3
timwilky
timwilky's Avatar
Have you got the sprocket?.
Ride upto my place (clayton le woods) and I will fit it for you.
If you must use a garage. Give Brian at Wheelton garage a bell. He is a one man band. does good work and been doing for 40 years.
Not Grumpy, opinionated.
Old 14-06-09, 01:14 PM   #4
timwilky
timwilky's Avatar
Or there is Dave Hill who does mobile, I haven't got his number but can get it as his brother only lives a few doors from me
Wheelton garage number is 01254 832008 but I know Brian is away until the 16th
Old 14-06-09, 01:39 PM   #5
beanie79
Haven't got the sprocket yet. But will be ordering it. I've read on previous threads that JT Stainless Steel ones are good ones to get. Once I've got it I'll pm you and if you still have any free time at that point I could pop up, if that's ok with you?
Old 14-06-09, 01:45 PM   #6
beanie79
I've tried the 3 o'clock test and there's no movement whatsoever (could be cos my girly arms aren't strong enough) and I've checked the tension on the chain and it is currently at 20mm.
Old 14-06-09, 02:27 PM   #7
timwilky
timwilky's Avatar
Yeah no problem, free most of the time, make sure you get both front and back sprockets, normally I would suggest B&C Express for mail order
Old 14-06-09, 02:50 PM   #8
beanie79
I'm going to go for Renthal Standard Size Ultralite front and Renthal Hard Anodised Rear. Do these sound ok?
Old 14-06-09, 05:58 PM   #9
timwilky
timwilky's Avatar
Personally I would avoid hard anodised as they don't tend to last. Also as you are not changing your chain, you need to ensure you have the same size sprockets.
Old 14-06-09, 06:06 PM   #10
beanie79
I've actually ordered a new chain as well, gone for JT Steel Sprockets with Tsubaki X ring chain. Figured I didn't pay for the other chain and it's probably pants so for piece of mind went for something that people recommended.
Or the sprockets might end up being Chiaravalli, but either way, steel. Ordered them/it from B&C Express. Final Drive kit.
Hope this is ok.
Cardiff Garages / Lockups gettin2dizzy South & West Surfers 25 26-02-08 07:51 AM
Garages - servicing, etc. Ping The Essex Lounge 7 25-01-08 02:55 PM
Anyone know about building garages? monkey Idle Banter 12 05-09-07 11:43 PM
Sheds/Garages rob13 Idle Banter 15 02-02-06 05:34 PM
Garages. One Reccomendation and one warning. Nekkid SELKENT 4 06-08-05 07:56 PM
