Old 18-06-09, 11:02 AM   #1
vandaman
Default Rear Shock rebuild
I race a 2008 sv650 and am not allowed to replace or modify my shock.How do I rebuild and recharge my shock without leaving any signs of having taken it apart?
Old 18-06-09, 11:11 AM   #2
BoltonSte
Default Re: Rear Shock rebiuld
Pretty sure you can't rebuild the stock SV shock.
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 18-06-09, 11:32 AM   #3
jambo
jambo's Avatar
I'm afraid it's not a service I've seen offered. GSXR / ZX6R shocks etc can be rebuilt for around £100, but the SV item can have the spring replaced and that's about it.
Besides, it'd be cheating
Jambo
Old 18-06-09, 12:42 PM   #4
vandaman
Cheating scmeating.I am a 36 year old fat bloke racing against 15 and 16 year old kamakazi pilots.I doubt if the latest Ohlins would make a difference.I have taken the shock apart.(have rebuild many rebuildable ones before) I can see the problem with the valving,and will put in thicker oil.The problem is with recharging the Nitrogen without a valve.Someone sugested liquid nitrogen or dry ice,that will expand int a gas.Has antbody tried this.
Old 18-06-09, 01:58 PM   #5
jambo
jambo's Avatar
Wasn't taking it too seriously, I've spoken to enough racers to understand that that what's legal is precisely equal to what you can get away with without being caught
I'm afraid at the part you've taken the shock apart you're well outside what I can offer help with. Using liquid nitrogen sounds a little bodge-tastic, might work but would make the internals brittle during re-assembly which might be bad news for the seal, and guessing the right ammount to give the desired pressure at room temperature as a gas is going to be a bit tricky.
That said, I've never done it and wouldn't know what I was doing if I did. So I wish you the very best of luck, and hope someone better suited than me turns up.
May be worth PM'ing Rob#70 as he's probably the most likely to know.
Jambo
Old 18-06-09, 09:29 PM   #6
vandaman
Default Re: Rear Shock rebuild
Thanks Jambo.
I sent him a mesg.Lets see what he comes up with.
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
rear shock philsv650n Stuff Wanted 5 23-10-07 05:54 PM
SV Rear Shock "Rebuild" SoulKiss Bikes - Talk & Issues 8 16-07-07 06:53 PM
ZX6 rear shock andyb For Sale - SV's and SV related items 2 26-02-07 10:45 AM
Rear shock latts650s SV Talk, Tuning & Tweaking 1 09-08-05 09:17 AM
