Old 20-06-09, 08:00 AM   #1
FlyinCustard
Default Scottoiler Fill Up
How do fill the little bottle up?
I searched for scottoiler on the forum but couldn't see a "how to fill it up" question just "where or how do you put it on the bike"
If there is a thread already showing this point me in the right direction and i'll save every repeating themselves
There is a tube that runs from under the seat into the top of the bottle is that it?
Alternate i can see the bottle is bolted on do you remove it and fill it up?
Rich
Old 20-06-09, 08:06 AM   #2
xXBADGERXx
Default Re: Scottoiler Fill Up
There will be a square black piece of rubber plugged into the top of the Scottoiler just to one side near the adjuster knob for flow . It will be wedged into a channel of sorts , in the top of that bit of black rubber will be a round plastic spigot . You put the filler tube of your new oil into that once the filler tube has a white spigot in it , press into the black bit and squeeze your bottle , release , squeeze , etc ...... it`ll fill up in no time at all
And just in case , have a look here as well http://www.scottoiler.com/support_fitting.asp
I think you may also have to set the adjuster to the "Prime" position to do this , but remember to put it back to whatever setting it was on otherwise it will eject the oil out everywhere in no time at all on the first run you do
Old 20-06-09, 08:34 AM   #3
FlyinCustard
Cheers Badger
£81.73 to fill up the family car! Berlin Idle Banter 26 22-04-08 07:38 PM
How to fill a Scottoiler Stu Bikes - Talk & Issues 3 05-02-07 09:47 AM
Bet you all fill up. Bluepete Idle Banter 4 29-10-06 09:16 PM
Oil fill level, over or under. Blindly SV Talk, Tuning & Tweaking 3 13-05-06 04:55 AM
grab rail gaps is there something to fill em in? i love my svs SV Talk, Tuning & Tweaking 8 10-09-05 03:52 PM
