Old 22-06-09, 08:53 AM   #1
ThEGr33k
Thumbs up Best Suspension set-up guide Ive found.
Good Morning,
Well I have been playing around with my suspension for a while now trying to get it feeling just right. I think ive done that and all along ive been trying to run with too much front compression dampening basically.
Anyway, my story over, here is something I found just having a look to see if what ive adjusted recently is what might have caused what ive been feeling upto now. I found this which I think is great. Its easy to follow and explains what you should/shouldn't feel.
It only talks about the suspension setting's not ride height etc, but thats not something most people play with and if you do its all down to personal taste like many things.
Anyway, have a read and discuss it. If you have any more questions then I might be able to help you, ive learnt a lot with my playing about so I might be able to help.
Cheers!
Old 22-06-09, 11:18 AM   #2
Paul the 6th
Paul the 6th's Avatar
Default Re: Best Suspension set-up guide Ive found...
ghey-ist thread ever... only joking! will give it a proper read and try setting my suspension up when I've a new rear tyre on
Old 22-06-09, 11:22 AM   #3
ThEGr33k
It is now you have replied
I will give it a proper read and try setting my suspension up when I've a new rear tyre on
Coolio. Well if you want any help then Ill hapily come over. I need to use you anyway so I will owe you
Old 22-06-09, 11:40 AM   #4
Paul the 6th
stay away from my pony! (will email ya later)
Aye no problem, need a new rear on (cords are showing!) then I can think about actually using all that adjustable suspension.
Old 22-06-09, 08:41 PM   #5
chakraist
Love that page. Took me about 3 hours to set up the front, but it's been great ever since. Delicious.
Old 23-06-09, 08:33 AM   #6
Dave20046
Dave20046's Avatar
Fancy doing mine for me nick? I can't be arsed.
No? fine
Old 23-06-09, 08:35 AM   #7
Dave20046
Dave20046's Avatar
Meant to do it ages ago but assumed I probably wouldn't notice the difference so never did. Is it really that noticeable on the sv?
Old 23-06-09, 10:46 PM   #8
Holdup
As the sv is only damping its minimal, i set mine up cable ties on stanchons and now have my fr suspension on softest preload, i norm have about 1.2mm distance between bottom yoke and cable ties so its close to recommend, i found when i frst did it it tipped in a lot better, now just to set up my rear suspension
Suspension ( the idiots guide) wheelnut Bikes - Talk & Issues 8 23-07-07 09:11 PM
Suspension Guide gettin2dizzy SV Talk, Tuning & Tweaking 9 19-06-07 06:59 PM
A definative guide to suspension/geometry setup tomjones2 Bikes - Talk & Issues 9 03-05-07 09:28 AM
Performance Bikes Suspension guide Performance Bikes SV Talk, Tuning & Tweaking 20 02-02-05 10:29 PM
Suspension tuning guide petetong SV Talk, Tuning & Tweaking 1 20-09-04 02:28 PM
