Old 22-06-09, 09:38 PM   #1
maclovin
Default any good deals on chain and sprockets ?
need a new chain and sprockets on curvey 99s . any body had a good deal on these items lately ( i have a 10% epay voucher if that helps ) what am i looking for teeth ? lenght ? grade ? as this is the first chain kit i have bought
thanks
Old 22-06-09, 09:51 PM   #2
Holdup
Default Re: any good deals on chain and sprockets ?
What ever takes your fancy tbh, ive got JT sprockets and tripple s chain which i bought as a kit, if you buy a kit MAKE SURE its is for and SV650S NOT A SV650 as the naked has a 110 link chain and 45 tooth rr sprocket whereas the S has a 108 link chain with a 44 tooth rr sprocket, i found out the hard way, ive got a naked CSK on my S so need to cut a link out now...
Old 22-06-09, 09:53 PM   #3
Girth
http://www.bandcexpress.co.uk/ Normally the cheapest and get the JT sprockets!
Old 22-06-09, 10:32 PM   #4
Luckypants
Luckypants's Avatar
Try Hunters motorcycles 0191 2618592. I got DID 112 link 525 pitch chain (so about same as SV) and sprockets for £72 delivered.
Old 22-06-09, 10:36 PM   #5
Luckypants
Luckypants's Avatar
So you have a 45T rear sprocket? Then why do you need to cut a link out? Naked and S have the same swingarm so it is only the sprocket size that affects the number of links (chain length). If you have a naked rear sprocket, stick with the naked chain length.
Old 22-06-09, 10:38 PM   #6
maclovin
got one from here code 3140.RE.APX looks ok £105 delivered hope its ok as money tight at minute but sounds ok on quality
Old 22-06-09, 11:13 PM   #7
Jamiebridges123
Yup what I got. Scottoilered and still strong and looking like new after 2000 miles.
Old 23-06-09, 08:32 AM   #8
Sean_C
JT sprockets- are they just called steel sprockets on the b&c express?
Old 23-06-09, 09:45 AM   #9
Girth
I believe so, if in doubt give em a call. They was very helpful when i ordered mine for the svthou.
Old 23-06-09, 10:31 AM   #10
wizurd
could try wemoto. im thinking of getting a chain for my thou from there. They've got a DID chain and sprockets for abut 80 quid. I've trying to find out the grade of them etc. If all is proper then they seem well cheap
good deals for new bikes nik_nunez Bikes - Talk & Issues 7 21-09-08 10:27 AM
got some good deals today Quiff Wichard Idle Banter 3 22-03-08 03:31 PM
Any good tyre deals on at the moment? Davies Bikes - Talk & Issues 4 02-10-07 01:09 PM
Best Chain Deals? Well Oiled SV Talk, Tuning & Tweaking 1 23-04-07 08:47 AM
New Chain & Sprockets - Regina Kit from Germany any good SpankyHam SV Talk, Tuning & Tweaking 5 25-07-06 10:45 AM
