Old 24-06-09, 08:07 PM   #1
steveg
steveg's Avatar
Default Tyre pressure loss?
Just checked my tyre pressures , normally check weekly but been 2-3 weeks .
Normally use 33F/37R , front ok however rear down to 30 PSI
Have checked for nails etc can't see any .
Is there any normal reasons why a rear tyre can loose 7 psi in 3 weeks without tyre damage ?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 24-06-09, 08:47 PM   #2
flymo
flymo's Avatar
Default Re: Tyre pressure lose
leaking valve possibly?
drop some washing up liquid in the valve and watch for slow bubbles
Old 24-06-09, 09:52 PM   #3
Razor
have you got good o-ring sealed steel or ally valve caps?
in warmer weather the valves can leak a little as they expand and contract, the standard plastic ones just don't cut it IMHO
Old 24-06-09, 10:14 PM   #4
steveg
steveg's Avatar
Caps are the standard plastic ones , will check valve for leak tomorrow and maybe look into getting some decent caps for a couple of quid
Cheers Steve
AKA Papa Smurf
Old 24-06-09, 11:55 PM   #5
monkey
If pressure's getting out through the valve caps there's a problem with the valve core, possibly just needs tightening or may be ill seating or have crud in it. I'm 99% sure valve caps are just dust caps which is probably why they're usually plastic cheap things.
You could put a little fairy liquid around the bead and base of the valve to check for leaks too. If you do this give the base of the valve a tug from side to side and look for bubbles.
Hope you get it sorted!
Old 25-06-09, 07:11 AM   #6
steveg
steveg's Avatar
After pumping up last night did 50 mile journey , checked this morning pressure not moved .
Got some dirty looks by passers by this morning when spitting to check valve for leak , no leak found .
Will keep an eye on it , also pushed the boat out by ordering some metal caps for 2.99
Will check pressures more regulary as have got lazy.
Cheers Steveg
AKA Papa Smurf
Old 25-06-09, 07:37 AM   #7
GavinD
temp fluctuation can cause pressure loss - like going into the winter seasons drops the ambient temp and make tyres deflate too
(not the cause here though as its been lovely weather)
Old 25-06-09, 07:53 AM   #8
timwilky
timwilky's Avatar
My brother had a problem with his Mille that the front tyre would deflate as he was riding it. No punctures found or leaky valve detected.
in the end he narrowed it down to the valve core, it was a cheap/nasty jobby and at high speed would leak but not when stationary.
Not Grumpy, opinionated.
Old 25-06-09, 12:04 PM   #9
vardypeeps
Check the valve internals are in properly other than that. 3 weeks sounds about right to me to loose 7 psi? Anyone else?
Old 25-06-09, 08:21 PM   #10
Don't use metal valve caps. They sieze to the valve threads and are generally a pain in the rse.
Plastic caps are fine, and more importantly don't look at all chavvy.
Tyre Pressure hindle8907 SV Talk, Tuning & Tweaking 6 23-06-09 08:53 AM
Tyre Pressure evilexel SV Talk, Tuning & Tweaking 5 20-02-09 10:57 PM
How much?(tyre pressure) Jussi Tyres 4 26-07-07 08:07 AM
What's your tyre pressure? Diveboy SV Talk, Tuning & Tweaking 28 03-05-06 07:05 PM
Tyre pressure? Rodger Wabbit SV Talk, Tuning & Tweaking 10 24-11-04 12:23 AM
