Old 25-06-09, 10:07 AM   #1
thedonal
Default Eliminating Visor Howl
Hey!
I've got an HJC FG-14 and once I'm over 30mph, the wind noise through the visor is noticeable and becomes considerable at 50mph+.
As I can't afford a shiny new quiet lid for some time, what can I do to get around this?
Is there any kind of seal I can add to the visor surround on the lid to cut this down/out?
Old 25-06-09, 10:10 AM   #2
Stig
Default Re: Eliminating Visor Howl
Wear earplugs.
Old 25-06-09, 10:10 AM   #3
Dave20046
Dave20046's Avatar
Only (highly impractical) thing I can think of is use some silicon sealant round the visor....
or do the above
Old 25-06-09, 10:10 AM   #4
chasey
Ear plugs?
Or, are you sure that you are closing the visor fully? I know that on my Arai I can think I have closed it fully closed it but there is just another like click to go .
Both options are cheap!
Old 25-06-09, 10:26 AM   #5
thedonal
Nar- is definitely closed fully. There's a bit of a gap still- I've tried loosening the screws on the sides of the lids and pulling the mechanism back a bit to make the visor more flush, but it doesn't do the whole job.
I thought of silicone seal- I guess the trick there would be to ensure it seals without pushing the visor and making it pop open...
Old 25-06-09, 10:30 AM   #6
Spiderman
Where the hell am I?
Spiderman's Avatar
I'd avoid silicon sealant as they may damage the visor itself. I dunno if they will but i wouldnt risk it.
My Spidey lid is an HJC and i get this from time to time, i just push it harder back at those speeds and it seems to control it a bit more.
Old 25-06-09, 10:34 AM   #7
Mogs
You could try the sponge stick on type draft excluder for around door frames.
Old 25-06-09, 11:47 AM   #8
thedonal
I think that may be a bit bulky- even the smaller ones. I might try a bit of insulation tape around the edge of the lid where the visor connects- at least this is an easily removable option if it doesn't work! I don't think there's a huge gap, but that high pitched blustering-whistling noise is getting a bit annoying now...
Old 25-06-09, 11:49 AM   #9
Stig
Ear plugs. No further adjustment required.
Old 25-06-09, 11:58 AM   #10
thedonal
I'll give those a go too...
Eliminating side stand switch … Diode Blue_SV650S SV Talk, Tuning & Tweaking 14 28-05-08 11:47 AM
Anti Fog Visor - Breath Guard or Visor insert Stu Bikes - Talk & Issues 50 14-11-07 10:17 AM
Keep your visor down Ol Boc Idle Banter 5 30-09-07 11:46 AM
Which visor cuffy Helmets 10 04-05-06 08:33 AM
Where did you get you visor from? Enzo Helmets 6 17-06-04 05:19 PM
