Old 26-06-09, 07:23 PM   #1
DANINPLYMOUTH
Default Guess my fork oil weight
Well after numerous issues getting my fork caps off, someone could have told me i had to undo the pinch bolts first. I managed to get my pump in there and suck out some oil. So now its question time
Forks full with 10w removed 200ml and put in 200ml 15W, this was Shell 15w which i beleive is pretty thick for 15w.
If this makes any difference il have to have another go and get some more fluid out, roll on tomorrow for testing time
Old 26-06-09, 09:12 PM   #2
flymo
flymo's Avatar
Default Re: Guess my fork oil weight
Problem with this approach is that its almost impossible to repeat the process reliably.
Old 26-06-09, 09:27 PM   #3
DANINPLYMOUTH
I know but i measured the same out of each leg then put the same back in so i was sort of hoping that it would stiffen the front up a bit at little cost
i have harder springs just needed thicker oil
Old 26-06-09, 09:32 PM   #4
flymo
flymo's Avatar
Its pretty hit and miss though, the oils may not blend properly and may blend differently in each fork. Why not just empty the forks and do it properly? Doesnt take that long to do.
Old 27-06-09, 07:19 AM   #5
DANINPLYMOUTH
I will in a little while think it was more of an exercise to see if i could do it. You see im not the mechanically able but guess its not much more work to do so will do it properly soon
Old 27-06-09, 07:53 AM   #6
theshed
been thinking of doing mine but dont know how to do a proper job so does anyone have a step by step guide how to
gsxr front fork springs, rider weight Bibio SV Talk, Tuning & Tweaking 32 19-10-08 12:24 PM
Fork oil weight. Jase22 SV Talk, Tuning & Tweaking 6 06-06-06 03:58 PM
What amount and weight fork oil is in the SV650 2004 model? Joe110 SV Talk, Tuning & Tweaking 3 02-05-06 05:41 PM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
Fork oil weight kern0079 SV Talk, Tuning & Tweaking 21 30-04-05 05:11 PM
