Old 30-06-09, 04:55 PM   #1
leesh00
Default Trouble at 8,000 RPM
I took the bike out for a run yesterday and found that when I got to 8,ooo rpm the power kept dropping off, I played with the throttle and it did get passed it but didnt feel quite right even then.
It was yesterday so probably the highest temps ive had it out in - dont know if this might have effected it? I had it serviced a couple of months ago spark plugs changed and k & n cleaned.
Any ideas and tips where to start please
Old 01-07-09, 07:54 AM   #2
Alpinestarhero
Default Re: Trouble at 8,000 RPM
Which model year is your SV to start with
Old 01-07-09, 12:32 PM   #3
vardypeeps
Is it restricted also?
Old 01-07-09, 02:11 PM   #4
johnnyrod
johnnyrod's Avatar
The foam hasn't fallen off the underside of the tank has it?
Old 01-07-09, 02:13 PM   #5
Viney
Dont go above 7900rpm then
HTH
Old 01-07-09, 06:09 PM   #6
leesh00
Its a 99 and not restricted
Old 01-07-09, 06:14 PM   #7
sunshine
dont roll off the throttle and you wont lose power
Old 02-07-09, 12:37 AM   #8
xXBADGERXx
I something loose under the tank like a heatshield or something ? Sometimes these can flap about and block an air filter giving you symptoms similar to this .
Old 02-07-09, 11:19 AM   #9
johnnyrod
johnnyrod's Avatar
My suggestion also. Same syptom but lower downt he rev range, 6k or so I think. Seemed very repeatable which confused the crap outta me for a while.
Old 03-07-09, 09:34 AM   #10
boo86
run some red ex through it. Unless you're confident with a carb strip down. At 10 years old I imagine some **** has built up in the carbs. It's either starved of air or fuel. Doesn't sound like an electrical prob. Check the in tank fuel filter too. I've had huge clumps of rust stuck in mine before on other bikes. I'd put money on it being a petrol delivery prob some-where in the fuel sysytem be it tank or carb.
org trouble kwak zzr Idle Banter 5 22-06-09 07:45 PM
HID trouble. yorkie_chris SV Talk, Tuning & Tweaking 33 30-12-08 12:22 PM
car trouble rowdy Idle Banter 18 16-08-08 04:37 PM
In trouble again timwilky Idle Banter 13 17-07-07 07:49 AM
In Trouble timwilky Idle Banter 28 29-05-07 01:52 PM
