Old 01-07-09, 07:42 PM   #1
ArtyLady
Default .
Old 01-07-09, 07:49 PM   #2
orose
Default Re: Computer problem
The all-seeing google suggests the file is part of the drivers for a Canon CanoCraft, whatever one of those is.
Easiest approach is probably to reinstall that software, if you have it, then uninstall it again.
Old 01-07-09, 08:18 PM   #3
orose
I'd go with removing it - the warning is just paranoia on windows' part, because it has an internal counter which it doesn't trust.
Old 01-07-09, 08:28 PM   #4
ThEGr33k
If you feel like uninstalling it you could stop the thing running using MSconfig in Run on the start menu. Go to the last tab to the right on top and check which one it could be and uncheck it.
While your there you can check other entries too that you dont want to start with windows, this will speed up the system.
HTH
computer problem custard Idle Banter 19 06-09-08 12:50 PM
Computer Help... poisonidea Idle Banter 4 10-01-07 01:40 PM
computer problem kwak zzr Idle Banter 99 16-09-06 12:46 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
